    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Question ...
    36 Posts 17 Posters 5.0k Views 17 Watching
    • RayOchoaR Offline
      RayOchoa
      Im sorry if i ask an ovious question but what does it mean to bevel?
      CaR DeSiGnS bY mE
      http://ray-ochoa.com
        remus
        http://farm4.static.flickr.com/3035/2438018922_8f65b18496.jpg
        If you cant read the writing, the one of the left is bevelled.
          Daniel S
          Here I put examples of what I think a script for bevel edges must do.
          Like i cannot make it with SketchUp, the examples I make looks like a chamfer tool. In the first example i put a normal cube, a chamfered cube and the bevel tool. The other examples are the normal shapes and the chamfered result. I cannot make the bevel in sketchup for the examples but will be the same rounded (like the cube that says ยดThis wayยด).
          Daniel S
            I agree, Chris. I'm kind of glad I don't know enough about Rubies to write one.๐Ÿ˜‰
            While I never build furniture with sharp edges, I rarely bother with beveling or radiusing edges in my SketchUp drawings of that furniture. Those details may add some realism but aren't usually worth the time they take to create. If the bevel is a large part of the design as in Gary Rogowski's table (the one in my video clip), I would certainly add it. In that case it wasn't a complicated thing to do with Offset and Autofold. For small radiused edges, if I need to show them, I prefer to insinuate them with Offset, Soften and Hide. The appearance is believable without the large increase in entities. For my use, automating that would work as well as a beveling plugin most of the time.
              Daniel S
              Daniel, if I was a machinist and you handed me those parts and said you wanted a bevel on the edge, I would put a chamfer on them as you have drawn. You would have to tell me you want a radius on the edge to get what you show in the cube labelled "this way".
              So perhaps a plugin that does both is what folks want or need?
              The following comes from the Wikipedia
              http://en.wikipedia.org/wiki/Bevel
              A beveled edge refers to an edge of a structure that is not perpendicular (but instead often at 45 degrees) to the faces of the piece. The words bevel and chamfer overlap in usage; in general usage they are often interchanged, while in technical usage they may sometimes be differentiated as shown in the image at right.
              http://upload.wikimedia.org/wikipedia/commons/f/f1/Bevel_and_chamfer.JPG
              Bevel top, Chamfer bottom
                A bevel would be similar to a chamfer This countertop has a bevel or a chamfer on the edge.
                http://www.graniterocktops.com/images/edges/edge_large_bevel.jpg
                While we're at it, a fillet is a concave curve between two surfaces at angles to each other. This bicycle frame has fillets between the tubes.
                http://www.kirkframeworks.com/raw fillet seatcluster 400.jpg
                Remus, in your drawing, the one on the right has a radiused corner, not a beveled corner. the one on the left appears to have a simple square corner.
                  Daniel S
                  Here are two video examples in the zip attached.
                  One for chamfer, other for bevel. Of course that bevel need to put a radius...
                  Daniel S
                  In the video you will see a variable radius...
                  Chamfer-bevel video.zip
                  • StinkieS Offline
                    Stinkie
                    @whaat said:
                    I had started work on a bevelling script. It was not nearly finished when my hard drive crashed and all was lost. It shouldn't be too hard to redo the work but I'm not committing to any new projects right now. My wife will kill me if I start another Ruby project before getting some work done in our basement. ๐Ÿ‘Š
                    Too bad! Of course, I understand. ๐Ÿ˜„
                    Any other takers? Remember: you'll be considered a hero! ๐Ÿ’š
                      CPhillips
                      Maybe something like this?
                      http://sketchyphysics2.googlecode.com/files/Bevel.gif
                        remus
                        Looks very nice, one question though, does it do arcs?
                        (and can i have a copy? pretty please ๐Ÿ˜† )
                        • Jean-FrancoJ Offline
                          Jean-Franco
                          Hi, that would be a fantastic tool for me !
                          Jean-Franco
                            Daniel S
                            Itยดs AMAZING Chris!!! ๐Ÿ˜ ๐Ÿ˜ ๐Ÿ˜
                            I donยดt know how you make it. I was doing this kind of bevel with offset all faces, delete the original geometry and triangulate the vertices. but for making it takes a lot of time.. and have to use a lot of plugins.
                            It works for curved faces?
                            Daniel S
                            curved faces
                              remus
                              Just a little alternative thing:
                              http://farm3.static.flickr.com/2134/2446420344_e19c2d11a6.jpg
                              Its not really bevelling, more of a fillet, but not a bad result ๐Ÿ˜‰
                              how to:
                              1. buy subd and smooth
                              2)select the shape to fillet
                              3)subdivide a couple of times
                              4)subdivide and smooth
                                CPhillips
                                Looks like it works with curves and arcs.
                                • soloS Offline
                                  That looks awesome, any ideas when and where it will be available?
                                  • Yet another valuable tool * ๐Ÿ‘
                                    a4chitect
                                    thats a nice one chris!! beautiful ๐Ÿ˜
                                      CPhillips
                                      Not long. Right now its a bit fussy about the geometry. GTA coming out on Tue might cause delay. ๐Ÿ˜‰
                                        remus
                                        Not to much of a delay i hope ๐Ÿ˜†
                                        • BurkhardB Offline
                                          Burkhard
                                          Aii Stinkie, enjoy the last days with your girlfriend ๐Ÿคฃ
                                          [http://www.ia-plus.de(http://www.ia-plus.de)]
                                          • majidM Offline
                                            majid
                                            such a good script it would be ๐Ÿ˜„ ๐Ÿ˜ .... waiting to see ( but not so patient ) ๐ŸŽ‰
                                            • 2 / 2
