    Question ...
    36 Posts 17 Posters 7.1k Views 17 Watching
      Daniel S
      Here I put examples of what I think a script for bevel edges must do.
      Like i cannot make it with SketchUp, the examples I make looks like a chamfer tool. In the first example i put a normal cube, a chamfered cube and the bevel tool. The other examples are the normal shapes and the chamfered result. I cannot make the bevel in sketchup for the examples but will be the same rounded (like the cube that says ´This way´).
      Daniel S
        I agree, Chris. I'm kind of glad I don't know enough about Rubies to write one.😉
        While I never build furniture with sharp edges, I rarely bother with beveling or radiusing edges in my SketchUp drawings of that furniture. Those details may add some realism but aren't usually worth the time they take to create. If the bevel is a large part of the design as in Gary Rogowski's table (the one in my video clip), I would certainly add it. In that case it wasn't a complicated thing to do with Offset and Autofold. For small radiused edges, if I need to show them, I prefer to insinuate them with Offset, Soften and Hide. The appearance is believable without the large increase in entities. For my use, automating that would work as well as a beveling plugin most of the time.
          Daniel S
          Daniel, if I was a machinist and you handed me those parts and said you wanted a bevel on the edge, I would put a chamfer on them as you have drawn. You would have to tell me you want a radius on the edge to get what you show in the cube labelled "this way".
          So perhaps a plugin that does both is what folks want or need?
          The following comes from the Wikipedia
          http://en.wikipedia.org/wiki/Bevel
          A beveled edge refers to an edge of a structure that is not perpendicular (but instead often at 45 degrees) to the faces of the piece. The words bevel and chamfer overlap in usage; in general usage they are often interchanged, while in technical usage they may sometimes be differentiated as shown in the image at right.
          http://upload.wikimedia.org/wikipedia/commons/f/f1/Bevel_and_chamfer.JPG
          Bevel top, Chamfer bottom
            @rayochoa said:
            Im sorry if i ask an ovious question but what does it mean to bevel?
            A bevel would be similar to a chamfer This countertop has a bevel or a chamfer on the edge.
            http://www.graniterocktops.com/images/edges/edge_large_bevel.jpg
            While we're at it, a fillet is a concave curve between two surfaces at angles to each other. This bicycle frame has fillets between the tubes.
            http://www.kirkframeworks.com/raw fillet seatcluster 400.jpg
            Remus, in your drawing, the one on the right has a radiused corner, not a beveled corner. the one on the left appears to have a simple square corner.
              Daniel S
              Here are two video examples in the zip attached.
              One for chamfer, other for bevel. Of course that bevel need to put a radius...
              Daniel S
              In the video you will see a variable radius...
              Chamfer-bevel video.zip
              • StinkieS
                Stinkie
                @whaat said:
                I had started work on a bevelling script. It was not nearly finished when my hard drive crashed and all was lost. It shouldn't be too hard to redo the work but I'm not committing to any new projects right now. My wife will kill me if I start another Ruby project before getting some work done in our basement. 👊
                Too bad! Of course, I understand. 😄
                Any other takers? Remember: you'll be considered a hero! 💚
                • C
                  CPhillips
                  Maybe something like this?
                  http://sketchyphysics2.googlecode.com/files/Bevel.gif
                    remus
                    Looks very nice, one question though, does it do arcs?
                    (and can i have a copy? pretty please 😆 )
                    • Jean-FrancoJ
                      Jean-Franco
                      Hi, that would be a fantastic tool for me !
                      Jean-Franco
                        Daniel S
                        It´s AMAZING Chris!!! 😍 😍 😍
                        I don´t know how you make it. I was doing this kind of bevel with offset all faces, delete the original geometry and triangulate the vertices. but for making it takes a lot of time.. and have to use a lot of plugins.
                        It works for curved faces?
                        Daniel S
                        curved faces
                          remus
                          Just a little alternative thing:
                          http://farm3.static.flickr.com/2134/2446420344_e19c2d11a6.jpg
                          Its not really bevelling, more of a fillet, but not a bad result 😉
                          how to:
                          1. buy subd and smooth
                          2)select the shape to fillet
                          3)subdivide a couple of times
                          4)subdivide and smooth
                          • C
                            CPhillips
                            Looks like it works with curves and arcs.
                            • soloS
                              That looks awesome, any ideas when and where it will be available?
                              • Yet another valuable tool * 👍
                                a4chitect
                                thats a nice one chris!! beautiful 😍
                                • C
                                  CPhillips
                                  Not long. Right now its a bit fussy about the geometry. GTA coming out on Tue might cause delay. 😉
                                    remus
                                    Not to much of a delay i hope 😆
                                    • BurkhardB
                                      Burkhard
                                      Aii Stinkie, enjoy the last days with your girlfriend 🤣
                                      http://www.ia-plus.de
                                      • majidM
                                        majid
                                        such a good script it would be 😄 😍 .... waiting to see ( but not so patient ) 🎉
                                        • W
                                          Whaat
                                          Great job Chris! Looks awesome! As if there weren't enough reasons already to thankyou for your work!
                                          Looks like I won't be finishing my bevel script after all. Oh well! 😉 Looking forward to the release!
                                          Dale
                                          • StinkieS
                                            Stinkie
                                            Fantastic! Utterly fantastic!
                                            I think you got yourself a hit Ruby there! 👍 There doesn't seem to be an option to set the size of the bevel, though. Am I correct?
                                            Oh well. You win some, you lose some. 👿
                                            • 2 / 2
