    Question ...
    36 Posts 17 Posters 5.8k Views 17 Watching
    • StinkieS Offline
      Stinkie
      Hmm. We'll see how useful it is in that regard.
        remus
        Itd still be nice to have a proper beveling script though, where you could just select a face/edge, set the radius and press go.
        • FletchF Offline
          Fletch
          Gjenio,
          that thread DOES mention he's thinking about a bevel option... hopefully it will be integrated... I really want a bevel tool as well... and I think it's critically connected to the functions of the SubDiv/Smooth tool he's developing.
          my vote here for a bevel command! I've been looking for it for months!
          Fletch
          • W Offline
            Whaat
            I had started work on a bevelling script. It was not nearly finished when my hard drive crashed and all was lost. It shouldn't be too hard to redo the work but I'm not committing to any new projects right now. My wife will kill me if I start another Ruby project before getting some work done in our basement. 👊
            FYI, bevelling an edge is a very different operation than what my other script does and needs to be handelled in a completely different way. So, it didn't make sense to incorporate a bevel feature in my latest script.
            I really wonder if this feature will be in SU7... another reason that I may never finish that script.
            Cheers
              remus
              good point about bringing SU to a halt, maybe if there was some way to turn the bevel on and off, kind of like layers but with bevels.
                CPhillips
                Doesn't sound too hard. What do you see as the minimum feature set?
                • RayOchoaR Offline
                  RayOchoa
                  Im sorry if i ask an ovious question but what does it mean to bevel?
                  CaR DeSiGnS bY mE
                  http://ray-ochoa.com
                    remus
                    http://farm4.static.flickr.com/3035/2438018922_8f65b18496.jpg
                    If you cant read the writing, the one of the left is bevelled.
                      Daniel S
                      Here I put examples of what I think a script for bevel edges must do.
                      Like i cannot make it with SketchUp, the examples I make looks like a chamfer tool. In the first example i put a normal cube, a chamfered cube and the bevel tool. The other examples are the normal shapes and the chamfered result. I cannot make the bevel in sketchup for the examples but will be the same rounded (like the cube that says ´This way´).
                      Daniel S
                        I agree, Chris. I'm kind of glad I don't know enough about Rubies to write one.😉
                        While I never build furniture with sharp edges, I rarely bother with beveling or radiusing edges in my SketchUp drawings of that furniture. Those details may add some realism but aren't usually worth the time they take to create. If the bevel is a large part of the design as in Gary Rogowski's table (the one in my video clip), I would certainly add it. In that case it wasn't a complicated thing to do with Offset and Autofold. For small radiused edges, if I need to show them, I prefer to insinuate them with Offset, Soften and Hide. The appearance is believable without the large increase in entities. For my use, automating that would work as well as a beveling plugin most of the time.
                          Daniel S
                          Daniel, if I was a machinist and you handed me those parts and said you wanted a bevel on the edge, I would put a chamfer on them as you have drawn. You would have to tell me you want a radius on the edge to get what you show in the cube labelled "this way".
                          So perhaps a plugin that does both is what folks want or need?
                          The following comes from the Wikipedia
                          http://en.wikipedia.org/wiki/Bevel
                          A beveled edge refers to an edge of a structure that is not perpendicular (but instead often at 45 degrees) to the faces of the piece. The words bevel and chamfer overlap in usage; in general usage they are often interchanged, while in technical usage they may sometimes be differentiated as shown in the image at right.
                          http://upload.wikimedia.org/wikipedia/commons/f/f1/Bevel_and_chamfer.JPG
                          Bevel top, Chamfer bottom
                            A bevel would be similar to a chamfer This countertop has a bevel or a chamfer on the edge.
                            http://www.graniterocktops.com/images/edges/edge_large_bevel.jpg
                            While we're at it, a fillet is a concave curve between two surfaces at angles to each other. This bicycle frame has fillets between the tubes.
                            http://www.kirkframeworks.com/raw fillet seatcluster 400.jpg
                            Remus, in your drawing, the one on the right has a radiused corner, not a beveled corner. the one on the left appears to have a simple square corner.
                              Daniel S
                              Here are two video examples in the zip attached.
                              One for chamfer, other for bevel. Of course that bevel need to put a radius...
                              Daniel S
                              In the video you will see a variable radius...
                              Chamfer-bevel video.zip
                              • StinkieS Offline
                                Stinkie
                                Too bad! Of course, I understand. 😄
                                Any other takers? Remember: you'll be considered a hero! 💚
                                  CPhillips
                                  Maybe something like this?
                                  http://sketchyphysics2.googlecode.com/files/Bevel.gif
                                    remus
                                    Looks very nice, one question though, does it do arcs?
                                    (and can i have a copy? pretty please 😆 )
                                    • Jean-FrancoJ Offline
                                      Jean-Franco
                                      Hi, that would be a fantastic tool for me !
                                      Jean-Franco
                                        Daniel S
                                        It´s AMAZING Chris!!! 😍 😍 😍
                                        I don´t know how you make it. I was doing this kind of bevel with offset all faces, delete the original geometry and triangulate the vertices. but for making it takes a lot of time.. and have to use a lot of plugins.
                                        It works for curved faces?
                                        Daniel S
                                        curved faces
                                          remus
                                          Just a little alternative thing:
                                          http://farm3.static.flickr.com/2134/2446420344_e19c2d11a6.jpg
                                          Its not really bevelling, more of a fillet, but not a bad result 😉
                                          how to:
                                          1. buy subd and smooth
                                          2)select the shape to fillet
                                          3)subdivide a couple of times
                                          4)subdivide and smooth
                                            CPhillips
                                            Looks like it works with curves and arcs.
