    Just Released! Subdivide and Smooth
    extensions
    102 Posts 36 Posters 31.3k Views 36 Watching
    • erikBE Offline
      erikB
      Whaat,
      Just bought it ! Looked at the tutorial and dit some quick testing.
      Works like a charme !! Great work !! 😍
      It is a great improvement on SketchUp as a modeller, altough it is imho still intended as a formost rectangular modeller the occasional 'organic' bit can now be done in an eassy way inside SketchUP whithout using a different modeller.
      Thanks,
      erikB
      • FrederikF Offline
        Frederik
        Congratulations, Whaat..!! πŸ‘
        I'm looking forward to check it... Looks really great..!! πŸ˜„
        Cheers
        Kim Frederik
        • jujuJ Offline
          juju
          T's crossed, I's dotted, cash exchanged hands, but so did a certain script! FANKS MAN!
            todd burch
            Carl, Dale, whatever! I knew it was 4 letters and #2 was an "a". "whaat" was I thinking?!!!
            Tabb.
            • N Offline
              notareal
                Jorgensen
                Let the new kind of SU models roll πŸ˜„
                I eagerly awaiting the first work from the creative people in this group πŸ˜„
                Jorgensen
                ps. Biebel, please find a way to pay πŸ˜„ I'm looking foreward to se your work.
                • tinanneT Offline
                  tinanne
                  I bit πŸ˜‰
                  I have also seen this thread and not ventured in... you ruby guys are too smart for me!
                  This is really amazing. I just bought it and I'm looking forward to trying it out. Great job!
                  Executive Director : American Society of Architectural Illustrators
                  AIP 30 Competition opens soon. ASAI.org
                  Architectural Rendering
                  • jujuJ Offline
                    juju
                    Dang, SU must be updated to handle higher poly models. I keep on crashing SU with this plugin.
                      remus
                      Just a quick question, ow many polys does a subdivided chair, say, have?
                        krash88
                        Well, this chair was subdivided by hand, but I'd say it was fairly average to any chair I model in SketchUp and has 6674 faces. Some of those are tri's some are quads so it would be considerably higher if the model was triangulated.
                        http://i109.photobucket.com/albums/n65/krash88/BL-098CHR.jpg
                        • JClementsJ Offline
                          JClements
                          Whaat/Dale:
                          I purchased Subdivide. I want to thank you for your ingenious scripting and hardwork!
                          Questions/Observations:
                          1. Earlier I believe there were some issues with The Sword(aka Zorro)
                            1a. Will it work properly in Parallel Projection mode?
                            1b. Is Zorro.rb now redundant and therefore should be removed from the plugins folder?
                            1c. I see The Sword does not effect geometry outside of a group nor will it register if drawn ON a group. That is a nice refinement.
                          2. Does Subdivide have to the ability to save a copy of the original geometry (say to a hidden layer) prior to a Proxy being created?
                          3. Is there a way to temporarily hide the subdivided surfaces so that the "controlling" edges or interior surfaces of the proxy can be more easily selected (I'm thinking of the example in one of your videos where an interior plane was created which caused a "crease" in the middle of the subdivided planes).
                          4. Could there be a help button on the toolbar with options to view either the videos or to view any written documentation that may be available?
                          5. Is there any info about the smoothing icon/function?
                          6. I noticed if a "controlling" subsurface face was deleted and later recreated by drawing over an edge, then the Update Subsurface function was required before the new subdivsions would display even if the Auto Update was the default.
                            Jorgensen
                            Strange. If I have VRAY for SU loaded I can't use SubSmooth. The object simply turns black when I select "Subdivide and Smooth".....
                            Any ideas what can be the problem ?
                            Jorgensen
                            • soloS Offline
                              No problem here, I have Vray for SU and subsmooth works fine on Vista and Xp.
                                Jorgensen
                                Hmm, If I don't load VRayForSketchup.rb it works fine. So I must have somekind of conflict 😞
                                  todd burch
                                  Video card?
                                  • W Offline
                                    Whaat
                                    Zorro will cause bugsplats when used on a proxy and is completely redundant. You should delete that Ruby.
                                    1. Does Subdivide have to the ability to save a copy of the original geometry (say to a hidden layer) prior to a Proxy being created?
                                    No, you have to save a copy manually if you think it is required. I am not sure why this is necessary. The proxy IS the original geometry.
                                    1. Is there a way to temporarily hide the subdivided surfaces so that the "controlling" edges or interior surfaces of the proxy can be more easily selected (I'm thinking of the example in one of your videos where an interior plane was created which caused a "crease" in the middle of the subdivided planes).
                                      The easiest method is to select the subdivided surface with the Outliner window and right click->hide
                                    1. Could there be a help button on the toolbar with options to view either the videos or to view any written documentation that may be available?
                                      All present and future docs will be linked directly from the Smustard website.
                                    1. Is there any info about the smoothing icon/function?
                                      See video tutorials
                                    Thanks for purchasing!
                                    • W Offline
                                      Whaat
                                      Any particular repeatable sequence of events that cause the crash? Maybe it's a bug with the script.
                                      • W Offline
                                        Whaat
                                        @pixero said:
                                        Is it possible to have the extrude tool select faces by hovering just like the push pull tool?
                                        No, this is not possible. If you assign a shortcut key to the extrude tool, you can hover over a face and then press the shortcut key to extrude. It works well.
                                        • W Offline
                                          Whaat
                                          Coen has kindly opened a forum exclusively for support for 'Subdivide and Smooth'. Please direct your questions and comments there.
                                          Please start a new topic for each independent question (and provide a detailed subject line...not just "Question" or "Help")
                                          • O Offline
                                            osx59
                                            hello Whaat,
                                            I bought script, but it does not function on my macbook 2,2 Ghz and 4Go fo mem !
                                            on Sketchup Pro 6.0 (6.4.245)
                                            😒 😞 πŸ‘Š
                                            V
                                            • 2 / 6
