    Just Released! Subdivide and Smooth
    extensions
    102 Posts 36 Posters 28.6k Views 36 Watching
      kwistenbiebel
      On PC the flash tut works.
      Good tutorial Chipp! (the action is a little fast to follow though πŸ˜‰)
      I do wonder why you used the smoove tool in the end to add some bump. Couldn't that be done with the proxy modeling tool Whaat incorprated as well? Just curious.
      [EDIT]: Both the flash animations posted on this page seem to play at a really fast speed, making it impossible to follow what's going on. Is it just my PC, or is this intended? The speed prevents me from learning things about the plug.
      @Whaat,
      Congratulations, my friend, with the release of the plugin. πŸ‘
      Now if I just could find a way to purchase it without having a credit card I could join the party ..
      • PixeroP Offline
        Pixero
        Bought it! And really like it.
        After a quick test I have some questions.
        Is there a easy way of hiding the proxy geometry? (Preferable on a separate layer.)
        Is it possible to have the extrude tool select faces by hovering just like the push pull tool?
        • erikBE Offline
          erikB
          Whaat,
          Just bought it ! Looked at the tutorial and dit some quick testing.
          Works like a charme !! Great work !! 😍
          It is a great improvement on SketchUp as a modeller, altough it is imho still intended as a formost rectangular modeller the occasional 'organic' bit can now be done in an eassy way inside SketchUP whithout using a different modeller.
          Thanks,
          erikB
          • FrederikF Offline
            Frederik
            Congratulations, Whaat..!! πŸ‘
            I'm looking forward to check it... Looks really great..!! πŸ˜„
            Cheers
            Kim Frederik
            • jujuJ Offline
              juju
              T's crossed, I's dotted, cash exchanged hands, but so did a certain script! FANKS MAN!
                todd burch
                Carl, Dale, whatever! I knew it was 4 letters and #2 was an "a". "whaat" was I thinking?!!!
                Tabb.
                • N Offline
                  notareal
                    Jorgensen
                    Let the new kind of SU models roll πŸ˜„
                    I eagerly awaiting the first work from the creative people in this group πŸ˜„
                    Jorgensen
                    ps. Biebel, please find a way to pay πŸ˜„ I'm looking foreward to se your work.
                    • tinanneT Offline
                      tinanne
                      I bit πŸ˜‰
                      I have also seen this thread and not ventured in... you ruby guys are too smart for me!
                      This is really amazing. I just bought it and I'm looking forward to trying it out. Great job!
                      Executive Director : American Society of Architectural Illustrators
                      AIP 30 Competition opens soon. ASAI.org
                      Architectural Rendering
                      • jujuJ Offline
                        juju
                        Dang, SU must be updated to handle higher poly models. I keep on crashing SU with this plugin.
                          remus
                          Just a quick question, ow many polys does a subdivided chair, say, have?
                            krash88
                            Well, this chair was subdivided by hand, but I'd say it was fairly average to any chair I model in SketchUp and has 6674 faces. Some of those are tri's some are quads so it would be considerably higher if the model was triangulated.
                            http://i109.photobucket.com/albums/n65/krash88/BL-098CHR.jpg
                            • JClementsJ Offline
                              JClements
                              Whaat/Dale:
                              I purchased Subdivide. I want to thank you for your ingenious scripting and hardwork!
                              Questions/Observations:
                              1. Earlier I believe there were some issues with The Sword(aka Zorro)
                                1a. Will it work properly in Parallel Projection mode?
                                1b. Is Zorro.rb now redundant and therefore should be removed from the plugins folder?
                                1c. I see The Sword does not effect geometry outside of a group nor will it register if drawn ON a group. That is a nice refinement.
                              2. Does Subdivide have to the ability to save a copy of the original geometry (say to a hidden layer) prior to a Proxy being created?
                              3. Is there a way to temporarily hide the subdivided surfaces so that the "controlling" edges or interior surfaces of the proxy can be more easily selected (I'm thinking of the example in one of your videos where an interior plane was created which caused a "crease" in the middle of the subdivided planes).
                              4. Could there be a help button on the toolbar with options to view either the videos or to view any written documentation that may be available?
                              5. Is there any info about the smoothing icon/function?
                              6. I noticed if a "controlling" subsurface face was deleted and later recreated by drawing over an edge, then the Update Subsurface function was required before the new subdivsions would display even if the Auto Update was the default.
                                Jorgensen
                                Strange. If I have VRAY for SU loaded I can't use SubSmooth. The object simply turns black when I select "Subdivide and Smooth".....
                                Any ideas what can be the problem ?
                                Jorgensen
                                • soloS Offline
                                  No problem here, I have Vray for SU and subsmooth works fine on Vista and Xp.
                                    Jorgensen
                                    Hmm, If I don't load VRayForSketchup.rb it works fine. So I must have somekind of conflict 😞
                                      todd burch
                                      Video card?
                                      • W Offline
                                        Whaat
                                        Zorro will cause bugsplats when used on a proxy and is completely redundant. You should delete that Ruby.
                                        1. Does Subdivide have to the ability to save a copy of the original geometry (say to a hidden layer) prior to a Proxy being created?
                                        No, you have to save a copy manually if you think it is required. I am not sure why this is necessary. The proxy IS the original geometry.
                                        1. Is there a way to temporarily hide the subdivided surfaces so that the "controlling" edges or interior surfaces of the proxy can be more easily selected (I'm thinking of the example in one of your videos where an interior plane was created which caused a "crease" in the middle of the subdivided planes).
                                          The easiest method is to select the subdivided surface with the Outliner window and right click->hide
                                        1. Could there be a help button on the toolbar with options to view either the videos or to view any written documentation that may be available?
                                          All present and future docs will be linked directly from the Smustard website.
                                        1. Is there any info about the smoothing icon/function?
                                          See video tutorials
                                        Thanks for purchasing!
                                        • W Offline
                                          Whaat
                                          Any particular repeatable sequence of events that cause the crash? Maybe it's a bug with the script.
                                          • W Offline
                                            Whaat
                                            No, this is not possible. If you assign a shortcut key to the extrude tool, you can hover over a face and then press the shortcut key to extrude. It works well.
                                            • 2 / 6
