    Cordless Drill
    68 Posts 20 Posters 24.8k Views 20 Watching
    • boofredlayB
      boofredlay
      Thanks for the info Jim. Unfortunately the whole shebang seems to have failed. Using it the months prior the batteries were not holding a charge overnight. Then weeks prior I got an odd smell from the drill when using it, maybe too much sawdust build up inside I don't know. Then the final straw, either both batteries completely failed the same day or the charger stopped working.
      I had a Porter Cable funeral last weekend. 😒
        alan wood
        Hi Eric,
        In reply to your question they are Ni-Cd batteries.
        cheers
        Alan
        • G
          Gidon Yuval
          My absolute favourite tool of all time and the one I use most and which has never let me down and which is wicked work horse
          = pause to take breath=
          is my Makita Impact 12 v cordless driver.
          Light, powerfull and reliable.
          The impact action makes driving screws about 300% easier.
          Granted, it's not realy siutable as a drill, but as a driver it can't be beat.
          If you don't know where you're going, you're never going to get there.
          • boofredlayB
            boofredlay
            Thanks again guys, time to go shopping.
              Sawduster
              Here are some pictures of my only styleof cordless drills.
              http://xs107.xs.to/xs107/06395/Pushdrill.jpg
              For small holes.
              http://xs107.xs.to/xs107/06395/EggBeater.jpg
              For holes a little larger,
              http://xs107.xs.to/xs107/06395/Brace.jpg
              and for large holes.
              May all your dimensions be the sum of their total.
              Jerry
              http://www.sawdustersplace.com
              • jeff hammondJ
                if you're main task is driving screws and/or bolts, i highly recommend This one or This one..
                these new litium ion batteries are amazing compared to what's been out there for the past few years.. very quick charging, comparatively very light and small, and so far the batteries appear to last longer (i've had two of the makitas for over a year now and the batteries are not loosing their memory)...
                the impact drivers themselves are amazing simply because of the amount of torque they produce -- driving 3" screws overhead is easy now..
                i use corded drills for boring holes but if i were to go back to the cordless offerings, i'd definitely get the ones with lithium batteries...
                • boofredlayB
                  boofredlay
                  Thanks Jeff.
                  • T
                    titmas
                    between my partner and i we have the following cordless drills-driver-impacts
                    Dewalt 14.4v impact - good all around shop driver
                    Dewalt 14.4v drill- limited use due to short battery time but can drill about 10- 2" holes in plywood on one charge.
                    Dewalt 18v impact- this is a literal nut buster
                    Dewalt 18v drill- can handle most everything we throw at it in the shop or the field
                    Hilti 15v drill- tremendous torque and fast speed for drilling in lumber but limited run time compared to others. hammer drill mode is fast for drilling Tapcons
                    Bosch 10v Li impact- great tool for hardware install, small but packs plenty of run time and torque. can drive 3" deck screws in PT with ease but i rather not push it too hard.
                    Bosch 10v Li drill- very limited hole size, 1/2" max, and power but fits in small places like inside cabinets or a tool box
                    Hitachi- all garbage
                    the hammer drill feature is nice for limited use(its hard on the drill and the user too) but rarely do i ever use it. i have corder Hilti hammer drills that i use for all concrete drilling applications.
                    • boofredlayB
                      boofredlay
                      Thanks again for all your replies.
                      I battled a nasty cold through a ton of deadlines the past week so I had no chance to shop until yesterday.
                      Well today at lunch I got me a Milwaukee 18v Lit-Ion 1/2" compact driver/drill.
                      http://www.cpomilwaukee.com/images/product/medium/2601-22.jpg
                      I know, nobody here recommended it but I did some other research, looked online for prices, did some shopping (all in the past two days) and decided on the Milwaukee. It was cheaper to buy locally than to get the sale price I linked to above.
                      πŸ‘
                      I could not see the need for an impact driver as the main use for me would be household repairs and the occasional garage wood shop (if I ever get the time again).
                      • T
                        titmas
                        happy for you Boo. for me, buying tools has to be one of the most enjoyable aspects of being a carpenter. almost as good as actually using them to build something. all things being equal tool brand choice is as personal and yet trivial as ones choice in underwear. everyones skivvies perform the same function but its your reason and preference on style, that makes it personal. happy drilling. FWIW http://www.rockler.com has all sorts of great drill bits and drivers of every type as well as screws to go along with it.
                        • boofredlayB
                          boofredlay
                          Thanks, I appreciate that.
                          • G
                            Gidon Yuval
                            Titmas is so right. I don't believe there is a huge difference between the different brands in terms of the tools ability to preform the task for which it was bought. For me, one of the major factors in deciding which brand to buy is the service track record of the company or vendor. Lets face it, any brand tool can break down or be found to be defective. The question then is what kind of service will you get from the people you bought it from. Will you be greeted with a "We're here for you, how can we help" type of attitude or will you find yourself wasting valuble time running around trying to get service and/or answers?
                            Also, I'm reminded of the time my daughter asked for a puppy for her birthday. She had very spcific ideas as to what the puppy she wants should be like. I told her to try and let go of those ideas and to go to the adoption center without a specific puppy in mind. I told her to just walk around for a while and that she and the puppy will choose each other. And that's exactly what happened. The puppy we adopted was nothing like she had described as 'the perfect puppy' but she (the puppy) has been a much loved member of the family for 5 years now.
                            It's a lot like that with tools. You'll pick up a tool and it will just feel right.
                            "It's a mystical bond between man and machine." - who said this and in what movie?
                            • ChiefwoodworkerC
                              Chiefwoodworker
                              I don't know, but I am going to take a wild guess it was one of the Wright Bros., credited in the US with the first airplane flight.
                              Joe....
                              http://www.srww.com
                              • G
                                Gidon Yuval
                                Not even close, Joe. πŸ˜’
                                • boofredlayB
                                  boofredlay
                                  Bobby Bolivia (Bernie Mac)
                                  http://www.gsc.com.my/2007/glitters/img/2transformers_01.jpg
                                  • G
                                    Gidon Yuval
                                    I knew you'd know it, Eric. πŸ‘ πŸ˜„
                                    "Bobby Bolivia, like the country but without the runs." 🀣
                                    Best part of the movie IMHO.
                                      Roger
                                      I think cordless drills are a pain in the ass (and please don't tell me I am using it the wrong way.)
                                      I had a Dewalt go bad and they wanted 65$ to put in a new trigger mechanism when I could buy a new one for $75. Then I bought a Ryobi and it worked fine until I had to get a new battery. They quit selling the old battery and the only difference between the old and the new was that they put in a key slot to keep them from being interchangeable. However, I found that the cells from the new battery fit perfectly into the old casing. And I kept going till the charger itself burnt out. Then my wife bought me a Milwaukee which is OK for the time being.
                                      But I find the brace and bit is hard to beat unless you are working with needle thin bits. I have yet to have a charger burn out for one of those. And I have used units older than I am (they were made of stone).
                                      http://www.azcreative.com
                                      • B
                                        bluecollar
                                        Once you have done Festool there ain't no going back. I honestly regret buying any other brand.
                                          Jackson
                                          Sorry, but I read all the way through this thread, folks passionately recommending different Makita models, De Walt, Bosch, Hilti, etc.... and then Boo's post saying he's settled on a.... Milwaukee! πŸ˜†
                                          ... and then Gidon comparing his cordless drill to his daughter's beloved pet dog. 🀣 Say what you like, but puppies are useless in wood, nevermind brick and concrete.
                                          Not at all a criticism, just really made me laugh, thanks guys!
                                          Keep on drillin'...
                                          p.s. I favour Makita- have an 18v Ni-Cd drill for driving and wood and a corded 240v percussion drill for the tough stuff.
                                          Jackson
                                          • G
                                            ggeezz
                                            I just recently did a LOT of research on the topic of cordless drills building this site. (BTW, my research suggests that Panasonic has the best drills.) But I just came across Festool recently, which surprised me. What's the deal with this brand? I haven't seen them sold anywhere and only talked about in two places. But when I see something mentioned only twice and the people say it's the best thing ever, I'm intrigued.
                                            • 1 / 4
