    TO MOVE MIRROR REFLECTION ПЕРЕМЕЩЕНИЕ,
    17 Posts 10 Posters 2.9k Views 10 Watching
    • S
      sahi
      For a basis the script is taken (Mirror3_1_.0.rb)
      The scratch - moves, reflects and copies the allocated object. With it it is easy to draw a ladder
      (It is enough to draw the first step and to specify a direction) to create mirror reflexion,
      To move on the specified distance. Allocate object, press the right button of a mouse,
      Choose "to MOVE MIRROR REFLECTION"
      zerkalo_eng.rb
      • TIGT
        Look at my Grow.rb too... this would do the same thing - even make a spiral / helical stairs in one go...
        • S
          sahi
          I do not have this script - I did not know. And now I write a script ladders (spiral)
          There is such script???
          • S
            sahi
            Has changed a script, now he draws a ladder.
            If to specify a spiral corner (an example 30)
            Then: the first mouse cliques - the beginning and the spiral centre.
            The mouse second cliques - spiral height.
            Distance = to an interval
            The script itself will define an interval from the set parametres (Distance, Height)
            English version. http://www.stroyka-r.ru/images/images/zerkalo_eng1.zip
            Русскую версию можно скачать с сайта указанного выше.
            • S
              sahi
              Has added a script. Now it turns a spiral to the left, in the right.
              If the distance = 0 that distance is defined by means of a mouse.
              http://i045.radikal.ru/0710/23/256287bf49e1t.jpg
              http://i018.radikal.ru/0710/7a/fbb16936f458t.jpg
              English version. http://www.stroyka-r.ru/images/images/zerkalo_eng2.zip
              • S
                sahi
                Excuse I has not absolutely understood? Well??? Badly???
                • G
                  gata
                  He says WELL !!! 😄
                  (Great = Well+++ !!!)
                  • S
                    sahi
                    Thanks.
                    • P
                      piyanan
                      I Have install this plugin(zerkalo_eng.rb)then restart and open sketchup go to tool plugin but i can't see this plugin to draw spiral stair
                      Help me please.
                      Thank
                      • S
                        sepo
                        The link does not work for me. It leads to a front page or something like that for the SU Ruassian forum. Not sure where to look for this script.
                        • S
                          stereofidelic
                          It doesn't work for me also. Link takes me to the first page of some russian forum and everything is on cyrilic script.
                          • D
                            Dik Harrison
                            Down loaded the .zip files. They are not in valid .zip format.
                            Have fun...
                            Dik
                            • M
                              maxosmedia
                              where is subj?
                              • B
                                blajnov
                                Here plagin on Russian, after the English version it is possible to appeal to the author, sahi on a forum:
                                http://www.stroyka.cc/
                                zerkalo.zip
                                • P
                                  piyanan
                                  I lay down at
                                  C:\Program Files\Google\Google SketchUp 6\Plugins
                                  Still can't see when open sketchup at plugin tool.
                                  Where I can use this plugin to draw spiral stair?
                                  • urgenU
                                    urgen
                                    ....right click mouse(context menu)->MOVING, ROTATION, COPY
                                    http://img371.imageshack.us/img371/6431/256287bf49e1ww3.jpg
                                    .... english version:
                                    zerkalo_eng.rb
                                    --pupil forever...------
                                    • P
                                      piyanan
                                      thank you very much.
