    TO MOVE MIRROR REFLECTION ПЕРЕМЕЩЕНИЕ,
    17 Posts 10 Posters 2.6k Views 10 Watching
      sahi
      For a basis the script is taken (Mirror3_1_.0.rb)
      The scratch - moves, reflects and copies the allocated object. With it it is easy to draw a ladder
      (It is enough to draw the first step and to specify a direction) to create mirror reflexion,
      To move on the specified distance. Allocate object, press the right button of a mouse,
      Choose "to MOVE MIRROR REFLECTION"
      zerkalo_eng.rb
        Look at my Grow.rb too... this would do the same thing - even make a spiral / helical stairs in one go...
          sahi
          I do not have this script - I did not know. And now I write a script ladders (spiral)
          There is such script???
            sahi
            Has changed a script, now he draws a ladder.
            If to specify a spiral corner (an example 30)
            Then: the first mouse cliques - the beginning and the spiral centre.
            The mouse second cliques - spiral height.
            Distance = to an interval
            The script itself will define an interval from the set parametres (Distance, Height)
            English version. http://www.stroyka-r.ru/images/images/zerkalo_eng1.zip
            Русскую версию можно скачать с сайта указанного выше.
              sahi
              Has added a script. Now it turns a spiral to the left, in the right.
              If the distance = 0 that distance is defined by means of a mouse.
              http://i045.radikal.ru/0710/23/256287bf49e1t.jpg
              http://i018.radikal.ru/0710/7a/fbb16936f458t.jpg
              English version. http://www.stroyka-r.ru/images/images/zerkalo_eng2.zip
                sahi
                Excuse I has not absolutely understood? Well??? Badly???
                  gata
                  He says WELL !!! 😄
                  (Great = Well+++ !!!)
                    sahi
                    Thanks.
                      piyanan
                      I Have install this plugin(zerkalo_eng.rb)then restart and open sketchup go to tool plugin but i can't see this plugin to draw spiral stair
                      Help me please.
                      Thank
                        sepo
                        The link does not work for me. It leads to a front page or something like that for the SU Ruassian forum. Not sure where to look for this script.
                          stereofidelic
                          It doesn't work for me also. Link takes me to the first page of some russian forum and everything is on cyrilic script.
                            Dik Harrison
                            Down loaded the .zip files. They are not in valid .zip format.
                            Have fun...
                            Dik
                              maxosmedia
                              where is subj?
                                blajnov
                                Here plagin on Russian, after the English version it is possible to appeal to the author, sahi on a forum:
                                http://www.stroyka.cc/
                                zerkalo.zip
                                  piyanan
                                  I lay down at
                                  C:\Program Files\Google\Google SketchUp 6\Plugins
                                  Still can't see when open sketchup at plugin tool.
                                  Where I can use this plugin to draw spiral stair?
                                  • urgenU Offline
                                    urgen
                                    ....right click mouse(context menu)->MOVING, ROTATION, COPY
                                    http://img371.imageshack.us/img371/6431/256287bf49e1ww3.jpg
                                    .... english version:
                                    zerkalo_eng.rb
                                    --pupil forever...------
                                      piyanan
                                      thank you very much.
