TO MOVE MIRROR REFLECTION ПЕРЕМЕЩЕНИЕ,
For a basis the script is taken (Mirror3_1_.0.rb)
The scratch - moves, reflects and copies the allocated object. With it it is easy to draw a ladder
(It is enough to draw the first step and to specify a direction) to create mirror reflexion,
To move on the specified distance. Allocate object, press the right button of a mouse,
Choose "to MOVE MIRROR REFLECTION" -
Look at my Grow.rb too... this would do the same thing - even make a spiral / helical stairs in one go...
I do not have this script - I did not know. And now I write a script ladders (spiral)
There is such script??? -
Has changed a script, now he draws a ladder.
If to specify a spiral corner (an example 30)
Then: the first mouse cliques - the beginning and the spiral centre.
The mouse second cliques - spiral height.
Distance = to an intervalThe script itself will define an interval from the set parametres (Distance, Height)
English version. http://www.stroyka-r.ru/images/images/zerkalo_eng1.zipРусскую версию можно скачать с сайта указанного выше.
Has added a script. Now it turns a spiral to the left, in the right.
If the distance = 0 that distance is defined by means of a mouse.
English version. http://www.stroyka-r.ru/images/images/zerkalo_eng2.zip
Excuse I has not absolutely understood? Well??? Badly???
He says WELL !!!
(Great = Well+++ !!!)
Thanks.
I Have install this plugin(zerkalo_eng.rb)then restart and open sketchup go to tool plugin but i can't see this plugin to draw spiral stair
Help me please.
Thank -
The link does not work for me. It leads to a front page or something like that for the SU Ruassian forum. Not sure where to look for this script.
It doesn't work for me also. Link takes me to the first page of some russian forum and everything is on cyrilic script.
Down loaded the .zip files. They are not in valid .zip format.
where is subj?
Here plagin on Russian, after the English version it is possible to appeal to the author, sahi on a forum:
http://www.stroyka.cc/
I lay down at
C:\Program Files\Google\Google SketchUp 6\PluginsStill can't see when open sketchup at plugin tool.
Where I can use this plugin to draw spiral stair? -
Where I can use this plugin to draw spiral stair?....right click mouse(context menu)->MOVING, ROTATION, COPY
thank you very much.
