    Array or Copy Multiple?
    27 Posts 14 Posters 4.6k Views 14 Watching
      randallwise
      Is there a command in SU like the array command in AutoCAD? I need to design a very large pergola for a commercial project. What is the best way to design? In AutoCAD I simply draw my first truss then use array to copy in pre-determined dimmensions.
      RSW
      P: randallwise
      • KrisidiousK Offline
        Krisidious
        in the rotate command.... hit ctlr for a copy...
        By: Kristoff Rand
          Rodentpete
          After a copy/rotate or a copy/move type x2, x10 (or whatever number) for however many copies of the process you want.
            sorgesu
            BTW, you can also copy/rotate ( or move/copy for that matter) and place your copied item to the outermost extreme of where you want the last copy and then input 2/ or 10/ to divide the space in between by multiple copies ( internal array as opposed to external array)
            Also when you do the external array do 2x NOT x2 as x may be read by SketchUp as some other command if input first.
            Susan Sorger
              tomsdesk
              Susan, I did not know about the internal array...this will be a big help when I know the number of spaces but don't want to figure the distance. Thanks!
              2.5D Trees & Shrubs!
                sorgesu
                Warms the cockles of my soul. Pleasure!
                Susan Sorger
                  tomsdesk
                  That's why I keep hangin' around with you kids...learn something new most every day. Happy Birthday, BTW!
                    sorgesu
                    Thanks Tom. I'm afraid that my birthday proves that I'm no kid. Sigh.
                    Susan Sorger
                      Well, I miss half a day and everything is answered...
                      Anyway, have a look at the "Making linear arrays" with the move tool and "Radial arrays" with the rotate tool in the SU Guide (both are somewhere half way down the pages).
                        Sawduster
                        I recently saw a nice tutorial using the radial array to make the copies for an animation of a door opening. Very cool.
                        May all your dimensions be the sum of their total.
                        Jerry
                        http://www.sawdustersplace.com
                        • EdsonE Offline
                          Edson
                          hi randall,
                          what you probably want to do is to create an array in which one single instance can be turned into an arrangement of objects in rows and columns, right? i do not think SU can do it in a single move. first you have to copy the object along a row (horizontally) then you select the entire row and copy it vertically. see the attached "tutorial".
                          tut_array.skp
                          http://www.mahfuz.arq.br
                          • Jean-FrancoJ Offline
                            Jean-Franco
                            Hi All,
                            I think the tutorial mentionned by Sawduster is a video on Design, Click and Build made by Dave Richards. The title is "Animating Your SketchUp Models".
                            Here is the link: http://blogs.taunton.com/n/blogs/blog.aspx?redirCnt=1&webtag=fw-designforum
                            Jean-Franco
                            Jean-Franco
                            • tinanneT Offline
                              tinanne
                              ok, I've tried it several times and read the tutorial. What am I missing..... trying to do an array.
                              Executive Director : American Society of Architectural Illustrators
                              AIP 30 Competition opens soon. ASAI.org
                              Architectural Rendering
                              • ToboboT Offline
                                Tobobo
                                Don't worry i had it hard at first to. Use Edson's skippy, and try 5x for multiple and /5 to divide the gap.
                                Keep trying it'll happen
                                Toby
                                Philippians 4:13
                                • EdsonE Offline
                                  Edson
                                  tina, who are you talking to?
                                  and what exactly are you trying to do and cannot do?
                                  • tinanneT Offline
                                    tinanne
                                    I was talking to anyone 😄 I have tried this before awhile ago and now again, but have never been able to get it to work.
                                    I'm not doing it for any specific project. Just want to know how to do it as the occasion arises.
                                    Thanks for your help 😄
                                    oh, just trying to do a circular array of any ole' object 😄
                                    • G Offline
                                      Gidon Yuval
                                      Here's a little tutorial. The methode is the same for linear or radial arrays.
                                      Hope it helps.
                                      Array tut.skp
                                      If you don't know where you're going, you're never going to get there.
                                        linea
                                        Thanks, Susan, Gidon, Edson.
                                        I had tried this before but could'nt really get the hang of it. I have a project to draw a fountain that will involve lots of concentric circular arrays. I can't wait to get on with it now! I'd struggle to draw a box if it wasn't for this forum.
                                        • EdsonE Offline
                                          Edson
                                          bravo, gidon. much more precise than the one i posted above.
                                          the same principles explained by gidon in his tut on linear arrays apply to radial ones: just instead of a distance one would enter an angle.
                                            ...the same principles explained by gidon in his tut on linear arrays apply to radial ones: just instead of a distance one would enter an angle.
                                            or start the copy/rotate by hand, snap to an endpoint on the circle and then hit the x-something or /-something... Good to create radial arrays that perfectly align to your (customly segmented) circles.
                                            • 1 / 2
