    Array or Copy Multiple?
    27 Posts 14 Posters 5.4k Views 14 Watching
    • EdsonE
      Edson
      hi randall,
      what you probably want to do is to create an array in which one single instance can be turned into an arrangement of objects in rows and columns, right? i do not think SU can do it in a single move. first you have to copy the object along a row (horizontally) then you select the entire row and copy it vertically. see the attached "tutorial".
      tut_array.skp
      http://www.mahfuz.arq.br
      • Jean-FrancoJ
        Jean-Franco
        Hi All,
        I think the tutorial mentionned by Sawduster is a video on Design, Click and Build made by Dave Richards. The title is "Animating Your SketchUp Models".
        Here is the link: http://blogs.taunton.com/n/blogs/blog.aspx?redirCnt=1&webtag=fw-designforum
        Jean-Franco
        Jean-Franco
        • tinanneT
          tinanne
          ok, I've tried it several times and read the tutorial. What am I missing..... trying to do an array.
          Executive Director : American Society of Architectural Illustrators
          AIP 30 Competition opens soon. ASAI.org
          Architectural Rendering
          • ToboboT
            Tobobo
            Don't worry i had it hard at first to. Use Edson's skippy, and try 5x for multiple and /5 to divide the gap.
            Keep trying it'll happen
            Toby
            Philippians 4:13
            • EdsonE
              Edson
              tina, who are you talking to?
              and what exactly are you trying to do and cannot do?
              • tinanneT
                tinanne
                I was talking to anyone πŸ˜„ I have tried this before awhile ago and now again, but have never been able to get it to work.
                I'm not doing it for any specific project. Just want to know how to do it as the occasion arises.
                Thanks for your help πŸ˜„
                oh, just trying to do a circular array of any ole' object πŸ˜„
                • G
                  Gidon Yuval
                  Here's a little tutorial. The methode is the same for linear or radial arrays.
                  Hope it helps.
                  Array tut.skp
                  If you don't know where you're going, you're never going to get there.
                  • L
                    linea
                    Thanks, Susan, Gidon, Edson.
                    I had tried this before but could'nt really get the hang of it. I have a project to draw a fountain that will involve lots of concentric circular arrays. I can't wait to get on with it now! I'd struggle to draw a box if it wasn't for this forum.
                    • EdsonE
                      Edson
                      bravo, gidon. much more precise than the one i posted above.
                      the same principles explained by gidon in his tut on linear arrays apply to radial ones: just instead of a distance one would enter an angle.
                      • GaieusG
                        ...the same principles explained by gidon in his tut on linear arrays apply to radial ones: just instead of a distance one would enter an angle.
                        or start the copy/rotate by hand, snap to an endpoint on the circle and then hit the x-something or /-something... Good to create radial arrays that perfectly align to your (customly segmented) circles.
                        • tinanneT
                          tinanne
                          WooHoo! I did it! Thank you so much Gidon!! and Edson! Very cool! πŸ˜„
                          • G
                            Gidon Yuval
                            Good for you, Tina!
                            I don't know if you did a linear array or a circular array so I thought I'd add a circular array tutorial just to be on the safe side.
                            Circular array tut.skp
                            http://www.sketchucation.com/forums/scf/sas/Newbie/Tutorial JPEG.jpg
                            • ToboboT
                              Tobobo
                              Ooooooo! Clever
                              Toby
                              Philippians 4:13
                              • tinanneT
                                tinanne
                                Thanks again Gidon. I did the circular array. I just wasn't typing the "formula" in the right order. Very cool, I'm exciting. This will make placing corbels on a turret MUCH easier!
                                • GaieusG
                                  @tinanne said:
                                  ...Very cool, I'm exciting...
                                  Hm...
                                  πŸ˜’
                                  • tinanneT
                                    tinanne
                                    LOL! WOOPS! 😳
                                    • GaieusG
                                      BTW Tina, are there really turrets (over) there? Here I could show you a real 12th century corbel though...
                                      πŸ˜„
