    [Tutorial] How to Array (Copy) along an Edge
    3 Posts 3 Posters 4.3k Views 3 Watching
    • H Offline
      Howard leslie
      See attached file.
      This tutorial was produced in response to this question on the newbie forum:
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=79&t=2065
      Howard L'
      Array along Edge.skp
      • TIGT Online
        Here's a variant to divide/array the cube along an edge at aknow total distance.
        Howard's version is best for setting the cube copies at given centres - e.g. 1+ 3 at every 4' = 12' total; whereas this way puts a cube at the start and end, and then spaces the intermediate copies equally in between - e.g. 11'7" total = 1+ 3 at 3'??" each.
        Divide Array along Edge.skp
          justry
          Cool! Hey, it also works with the rotate tool! You can use it to array or divide an object around a circle or an arc!
