Open more than one group?
What would be the technique for stretching a model of a house that has groups consisting of floor, walls, another floor, 2nd walls and a roof. As far as I can tell you can only edit one group at a time, Can you use the outliner in conjunction with the group edit to open more than one group?
I don't think any program allows that whether it is an Autocad Block, a Revit Family, a Datacad Symbol or a SketchUp Component/Group. Unless I just missed the boat on this one.
yesh I think it's called S.O.L.
lol
I cant comment on autocad but this is easily achieveable in Microstation by using a fence strech command.
HOLY MOLY LOOK AT BOO!
you're soo skinny... wow.. your face shrunk...
Thanks Kris.
Can you do this while editing two different groups at the same time? If so that is a neat trick and other programs should take notice. It would be a nice feature to be able to stretch a wall, roof and footing component at the same time in SU.
Autocad does have a fence stretch command but it works on "active" entities. I.E. lines, polylines, dimensions... that have not been designated into a block. And you can stretch as many as you want.
In order to stretch a sofa block for example, you have to edit/stretch the sofa block itself then stretch your walls etc. separately. -
Microstation uses the term cells rather than blocks. It also uses 3 types of cells; Orphan cells, Shared and unshared Cells. Orphan cells are another name for groups. Unshared cells are groups of elements brought into a drawing from a cell library file and are completely independant from each other instance within a drawing. Shared cells cannot be edited in anyway within a drawing, only via editing the parent within the library that it is stored within. This sounds like the autocad scenario that you refer to. Microstation has a toggle that allows the user to affect orphan & unshared cells during a fence stretch operation as shown on the attached image.
Nice feature, thanks for the explaination.
Register LoginAdvertisement
