    Taper?
    16 Posts 8 Posters 6.9k Views 8 Watching
      3eighty
      Is there a way to taper a long cyl??? Like an airplane body.
      • KrisidiousK
        Krisidious
        yes
        create the cylnder...
        select the top circle...
        select the scale tool...
        scale about the corners... should create a cone.
        By: Kristoff Rand
        • N
          not registered yet
          To taper a cylinder, you simply need to scale the face at one end either larger or smaller. But I think there's more to the shape of an airplane fuselage than a tapered cylinder.
          See what you think of this:
          Error 404 (Not Found)!!1
          (sketchup.google.com)
          -Gully
          • A
            alan wood
            Hi guys,
            I think there were a few people on the old forum who did a teach package on this. I think, one was Jean Lemire who is a member of this forum.
            Alan.
            • GaieusG
              Hi 3eighty,
              Gully's tuts are very intuitive, I'd suggest it to you .
              I also made a tut about tapering into a non-parallel shape (see it here) but for a fuselage a simple follow me would also do it. However an airplane body is not axisymmetrical (correct my English, Gully, if the term is not correct, please...)
              • D
                dylan
                Again, nice simple effective tut Gulley, good stuff!
                Another way to taper a cylinder similar to Kris's method is to highlite the top edge and in the Entity Info box and change the circle radius.
                http://dmdarchitecture.co.uk/
                • KrisidiousK
                  Krisidious
                  speaking of that dylan, have you ever wished you could change the square footage manually, by typing in that info box?
                  By: Kristoff Rand
                    3eighty
                    As always a BIG thank you to you all...Off to play now..
                    • D
                      dylan
                      I have never actually thought of that, but now you mention it..
                      • KrisidiousK
                        Krisidious
                        I can never get an acre to be an arce by drawing it. in a square... it's always off just a little in square feet...
                        if I could type it in that would be great... but then it would have to push it'self out along some edge and chose that edge.
                        ahhh to wish
                        By: Kristoff Rand
                        • GaieusG
                          I don't have any problem with hectars though (100 metres by 100 metres = 10,000 square metres).
                          Why don't you convert to some more logical measurement units?!
                          πŸ˜„
                          • Jean LemireJ
                            Jean Lemire
                            Hi folks.
                            See attached SU file. This an acre with an error of about 0.0000004 %.
                            Just ideas.
                            Acre.skp
                            • KrisidiousK
                              Krisidious
                              πŸ˜„
                              from your lips to our goverment's ears... we pray...
                              By: Kristoff Rand
                              • KrisidiousK
                                Krisidious
                                yes Jean, that's very good... but you've got your units set to decimal. so it's for some reason much more accurate.
                                I'm set on imperial... so taking Jean's que...
                                I took his? drawing... and converted it to imperial. and then it's exactly an acre. or 43,560 sq. ft.
                                so I guess if an imperial person wants a precise drawing, we need to draw in decimal then convert to imperial....
                                well thanks for the work around Jean... boy or girl, not sure?
                                don't take offense, my name is Kris with a K so I know...
                                By: Kristoff Rand
                                • jujuJ
                                  juju
                                  Looking at the signature it reads "(Johnny)" so I guess Jean is male and not female then. πŸ˜‰
                                  • Jean LemireJ
                                    Jean Lemire
                                    Hi folks.
                                    Yes, I use Johnny with my English speaking friends.
                                    Jean is the french for John.
