    Taper?
    16 Posts 8 Posters 6.9k Views 8 Watching
    • GaieusG
      Hi 3eighty,
      Gully's tuts are very intuitive, I'd suggest it to you .
      I also made a tut about tapering into a non-parallel shape (see it here) but for a fuselage a simple follow me would also do it. However an airplane body is not axisymmetrical (correct my English, Gully, if the term is not correct, please...)
        dylan
        Again, nice simple effective tut Gulley, good stuff!
        Another way to taper a cylinder similar to Kris's method is to highlite the top edge and in the Entity Info box and change the circle radius.
        http://dmdarchitecture.co.uk/
        • KrisidiousK
          Krisidious
          speaking of that dylan, have you ever wished you could change the square footage manually, by typing in that info box?
          By: Kristoff Rand
            3eighty
            As always a BIG thank you to you all...Off to play now..
              dylan
              I have never actually thought of that, but now you mention it..
              • KrisidiousK
                Krisidious
                I can never get an acre to be an arce by drawing it. in a square... it's always off just a little in square feet...
                if I could type it in that would be great... but then it would have to push it'self out along some edge and chose that edge.
                ahhh to wish
                By: Kristoff Rand
                • GaieusG
                  I don't have any problem with hectars though (100 metres by 100 metres = 10,000 square metres).
                  Why don't you convert to some more logical measurement units?!
                  πŸ˜„
                  • Jean LemireJ
                    Jean Lemire
                    Hi folks.
                    See attached SU file. This an acre with an error of about 0.0000004 %.
                    Just ideas.
                    Acre.skp
                    • KrisidiousK
                      Krisidious
                      πŸ˜„
                      from your lips to our goverment's ears... we pray...
                      By: Kristoff Rand
                      • KrisidiousK
                        Krisidious
                        yes Jean, that's very good... but you've got your units set to decimal. so it's for some reason much more accurate.
                        I'm set on imperial... so taking Jean's que...
                        I took his? drawing... and converted it to imperial. and then it's exactly an acre. or 43,560 sq. ft.
                        so I guess if an imperial person wants a precise drawing, we need to draw in decimal then convert to imperial....
                        well thanks for the work around Jean... boy or girl, not sure?
                        don't take offense, my name is Kris with a K so I know...
                        By: Kristoff Rand
                        • jujuJ
                          juju
                          Looking at the signature it reads "(Johnny)" so I guess Jean is male and not female then. πŸ˜‰
                          • Jean LemireJ
                            Jean Lemire
                            Hi folks.
                            Yes, I use Johnny with my English speaking friends.
                            Jean is the french for John.
