    ½ PIPE ALONG PATH
    12 Posts 6 Posters 3.3k Views 6 Watching
    • C
      Charlie__V
      Since there already is a pipe along path script[TIG],why not a ½ Pipe along path?
      I Imagine It useful For those designing pool slides and the like.
      Or Other uses I'm sure.
      Just thinking out loud.
      C
      • T
        tomsdesk
        If one could solve the changing orientation problem, I could see all sorts of uses...stair railings nonetheleast!
        Is it possible?
        2.5D Trees & Shrubs!
        • TIGT
          See the adjacent thread about make 'logs'. Didier already has a Balustrade tool...
          You could make a ExtrudeSelectedFaceAlongPath.rb... A sort of combination of my set of ...AlongPath... tools and RickW's CopyAlongPath... script
          Then you could draw any face shape you like - half pipe, cornice etc without the need to orient it at 90 degrees to the start of the path. You'd select the face and the path and it'd do it for you ? Alternatively you could use external face components - like Didier's Balustrade... script and extrude those along the path - ExtrudeSelectedComponentsFaceAlongPath.rb...
          This is all possible... but is it worth doing when you can already draw and do this with a little effort and pushpull/followme ? Perhaps an alternative idea would be a script that orients a selected face at 90 degrees to the start of a selected path for the later pushpull or followme... that way you use the inbuilt base tools for the main work, but we'd have a neat tool to start you off - OrientFaceToPath.rb ?
          • C
            Charlie__V
            TIG,
            Please humor me,but would there be any way to maintain the ½ pipe (profile) diameter in a static axis reference.
            Other words,always perpendicular/parallel to the path,no matter what the +/- path.
            Attached .skp "turns" along path.
            Hope that makes a wee bit of sense 😉
            Apologies per file size. 😳
            BTW,thanks for all your great scripts/hard work.
            C
            http://www.sketchucation.com/forums/scf/sas/Ruby/ELECTRIC%20CHORD.skp
            • D
              dtrarch
              Charlie-V
              This is the olde flat extrude issue.
              The profile will twist as it extrudes using the follow me tool.
              Al Hart had something started, but bailed before it was completed.
              I guess just too difficult to finish for him perhaps.
              Sure would be super to have this in hand as it would be useful for roadways, handrails and probably a bunch more.
              Next ??
              Dave
              • C
                Charlie__V
                Dave,
                I understand.was hoping the pipe along path author[TIG]possibly had a discovery.
                Next..........meaning new ball carrier?? 😄
                C
                • TIGT
                  The twisting is a part of followme. To keep it flat needs a new followme writing, which would be too much for mortal man - when he's not getting paid !
                  • CadFatherC
                    CadFather
                    this is what SU has been lacking for too long a time.. lucky Erez made that little gem called simuterra..still it would be great to have a tool that combines extrude along path and follow me and....... stays put at the same time.
                    wouldn't mind paying if such a tool was conceived
                    come on folks let's get the collection going!
                    • boofredlayB
                      boofredlay
                      Charlie, maybe you should post this in the SketchUp Wishlist Forum.
                      • D
                        dtrarch
                        Charlie-v
                        Next means the ball is handed off to ??
                        TIG-How much is enough to make you smile a little.?
                        HMMMM?
                        Dave
                        • TIGT
                          I smile inside.
                          • CadFatherC
                            CadFather
                            no but seriously (insert seriously smiley) - all these geniuses... the @last folks came up with follow me, stamp and create mesh...great ideas, remember?
                            now i think the kindness and generosity of these masters has been beyond words.. ...very... grateful
                            ..to have a 'driveby' plugin where you can lay a path on a terrain and have a profile follow it while keeping the car flat on the ground... wuooh (missing a smiley again)
                            ...to see some of these sirs work together to such achievement... TIG, Didier, Hal Rick and all those others...perhaps we could organise a ruby base camp in a warm resort where they would work in leasure (while we make sure they don't just go surfing)
                            the labourer deserves his/her wages ...who would buy this tool?
