    [Plugin] Ellipse script
    18 Posts 10 Posters 21.0k Views 10 Watching
    • Didier BurD Offline
      Didier Bur
      A tool to draw ellipses in 3D.
      Ellipse.zip
      DB
      • Joe WoodJ Offline
        Joe Wood
        Didier, will this work in SUp 5??
        Joe Wood
        woodsshop.com/
          Didier Bur
          Yes πŸ˜„
          DB
          • Joe WoodJ Offline
            Joe Wood
            Right on, thanks Didier, can't wait to try it out!
            Joe Wood
            woodsshop.com/
            • JClementsJ Offline
              JClements
              Thank you very much, Didier
                bellwells
                Just d/l the script and will try it out. Thank you so much for this, Didier. This will prove to be an extremely useful tool.
                Edit- I think "major" and "minor" axes should be switched?
                Edit Again - I would do it myself, but the code seems to be scrambled when I open it in Notepad.
                Ron
                  Didier Bur
                  Hi bellwells,
                  Major and minor axis are "switchable", yes. In my example, the major axis is smaller than the minor 😳
                  But it doesn't matter. I could call them "first" and "second" as well πŸ˜„
                  DB
                  • boofredlayB Offline
                    boofredlay
                    Very nice, thanks.
                      bellwells
                      @didier bur said:
                      Hi bellwells,
                      Well, I feel like a dork. Not the first time.
                      Ron
                        jchampe01
                        anyone know of a script that would equally divide an ellipse about the circumference a specified number of segments? Or an easy way to acomplish it?
                          mgfranz
                          I just found this utility and it works fine on a predefined plane, but it would be nice if I could just plug in some values and have the ellipse drawn for me.
                          "If you like what you do, it will never be work..."
                          In memory of Sam Maloof, 1916-2009
                          • W Offline
                            whitedavidp
                            Hi. I just managed to install this on Maker 2016 under Windows 10, 32-bit. I mean I can see it listed and checked among the Extensions under Preferences. But I do NOT see it anywhere else - especially under the Draw menu. I must be missing something. Thanks for any tips.
                              This is an ancient plugin and it appears it hasn't been updated to work in newer versions of SketchUp. There's the Ellipse plugin by Regular Polygon that does work, though.
                              You don't really need a plugin to draw an ellipse, anyway.
                              • Gus RG Offline
                                Gus R
                                Plugin doesn't work in SU 2021 or 2022. Kept trying to create an ellipse in both and I couldn't figure out what I was doing wrong. Fired up the old rig and it worked as usual on SU 2017. Yes, I know it's an oldie. Just a very useful plugin sometimes.
                                www.instagram.com/gusrobatto/
                                www.facebook.com/gusrobatto
                                  See the post I made immediately before yours.
                                  • Gus RG Offline
                                    Gus R
                                    Thanks Dave. I just installed that other plugin and it's so-so.
                                      What's wrong with it?
                                      I did all these ellipses with it. It worked fine for me.
                                      https://live.staticflickr.com/65535/51710306366_f4304e2465_z.jpg
                                      • Gus RG Offline
                                        Gus R
                                        It's fine. Just found that Arc Circles + will create an ellipse much the same like the old plugin.
