    [Plugin] Projection toolbar update
    30 Posts 18 Posters 52.2k Views 18 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      Here is an update (major revision) of my projection toolbar.
      What's new:
      · More user-friendly commands: click points instead of selecting objects for plane definitions and vectors
      · Better selection errors checkings
      · Project faces along Z and along vector gathered in one command.
      · ExtrudelineTool included
      · lines2cyl and credits commands suppressed
      · Construction line at intersection of faces enhanced: multiple selection supported
      · New icons
      · PDF doc included
      Enjoy,
      Unzip in Plugins folder.
      Read the doc...
      DB
      • CadFatherC Offline
        CadFather
        Thank you Didier - your toolbar has been a great friend in the past - i'm looking forward to see the changes. 😄
        EDIT: had a look at the new script (though i still have to read the doc)
        one question - how feasible to add 'project lines' along red/green?
        i am thinking of using it to extrude lines and have them intersect faces - very useful/quick when working with cad files
          Didier Bur
          Hi cadFather,
          I'm afraid I don't understand 'project lines along red/green' ?
          Using "project lines along vector" would not do the trick ?
          Please explain it to my tired brain...
          DB
            CadFather
            for some reason i can't upload an image - the tool i have in mind is the project along z
            • i was thinking of a keyboard shortcut which quickly projects lines along one of the other axis. to be sure the vector one works so don't worry about it...take a good rest
              (if you can).. 😲
            • U Offline
              urs0815
              hallo Didier,
              I installed the "projection toolbar", it works fine, BUT now the right mouse button doesn´t work how it should: when I activate an object and klick the right mouse button (to call the context-menu), the object is not active any longer.
              I use SU6free on MacOSX - I´ve tried it with a 3 button mouse and a Wacom tablett -> same problem
              • EdsonE Offline
                Edson
                didier,
                what can i say? u da man!!! one more fantastic script that will boost everyone's productivity.
                i tried all the tools and they worked perfectly on my mac running OS 10.4.11.
                regards and thank you once more.
                p.s.: would it be at all possible to control the distance between the two points needed to extrude lines along a vector via VCB?
                http://www.mahfuz.arq.br
                  Didier Bur
                  Hi Edson,
                  You can make it work this way, or did I forget something ? 😲 😲
                  Click a first point somewhere, drag the mouse in the direction you want the vector to be, then enter a number in the VCB. 😄
                  PS: multiwalltool tuto not forgotten 😉
                  Regards,
                  DB
                  • EdsonE Offline
                    Edson
                    yes, it does work. i have probably done something wrong when i tried before.
                    PS: multiwalltool tut not forgotten
                    thanks! i thought of that the other day but did not want to ask again since you have been giving us so much.
                    regards.
                    • free agentF Offline
                      free agent
                      this has become one of my many favourite scripts, but i cant assign keyboard shortcuts to the individual commands, any way of fixing this?
                      • X Offline
                        xrok1
                        i've been wanting this for a long time now. thanks to the new ruby search index and thankyou very much dedier. 😍
                        “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                        • X Offline
                          xrok1
                          Hmmm, check this out. if i select more than one line to project perp. to plane, only 1 projects???
                          try the file, select all the edges then the face obove it and try project perp. to plane.
                          project.skp
                            bluestone
                            it's really good one for AV designer
                              ckosio
                              thanks a lot....for sure I will it alot!
                              • DVERGERD Offline
                                DVERGER
                                Bonjour/Hello
                                J'ai certains icones en double, en français et en anglais (en vert sur l'image).
                                I have duplicate icons, in french and in english (in green on picture).
                                  Il y a 2 versions successives mélangées en même temps! 😉
                                  • DVERGERD Offline
                                    DVERGER
                                    J'ai "fr_projection_extension" et "projection_extension". Donc je vire "projection_extension". C'est bien ça?
                                    EDIT : C'est fait mais j'ai perdu les 4 derniers icones de la barre qui n'étaient pas en double.
                                    • X Offline
                                      xrok1
                                      great set of tools, thankyou.
                                      is there any chance to add a project along normal to the extrude lines tool? 💚
                                        LannorMov
                                        @didier bur said:
                                        Hi all,
                                        What's new:
                                        · New icons
                                        · PDF doc included
                                        Enjoy,
                                        Gracias Didier, solo gracias
                                        • sketcpeppe75S Offline
                                          sketcpeppe75
                                          recent release is projection v6 or v2? tanks to job
                                            Didier Bur
                                            It's V2 and can be found here: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=671
                                            DB
                                            • 1 / 2
