    Water with SU and render engine.
    extensions
    19 Posts 12 Posters 6.4k Views 12 Watching
    • soloS Offline
      solo
      Last week there was a call for a water tutorial, I was kinda busy so today I did a very quick model with a turbulance mesh and a water bump map. I rendered it with Podium, but believe that Kerkythea users can also use this model. I use a geodesic omni light you will notice, feel free to delete it and use your own style, or if you like the way the light gets distributed feel free to use it or even save it for future use.
      Instead of a drawn out tutorial (I am lazy) use the .skp and see what opacity levels, texture mapping etc I used.
      Hope this helps.
      http://img81.imageshack.us/img81/9250/200710151600529m50szd5.jpg
      Due to size restriction, please find attachment here:
      http://www.websitetoolbox.com/tool/post/supodiumforum/vpost?id=2224121&pid=21163160#post21163160
      http://www.solos-art.com
        Solo, you're killing us. Thanks! (Not for the killing part though... ๐Ÿ˜„)
        • EdsonE Offline
          Edson
          i propose to ban solo from this forum for a couple of weeks. he is out to humiliate most of us! turbulent water! come on, solo!
          edson mahfuz, architect| porto alegre โ€ข brasil
          http://www.mahfuz.arq.br
            alexander
            didn't you see all the little tiny fishes Edson ๐Ÿ˜„
            • K Offline
              kwick7
              I just started re-modeling a pool model I did years ago in College. I'll definitely be taking a look at this and seeing what I can do!
              Now.... what kind of advice do you have on waterfalls? ๐Ÿ˜„
              http://www.bigmug.net
              • FrederikF Offline
                Frederik
                Thanks for sharing, Pete! ๐Ÿ˜„
                Indeed users of Kerkythea can render this model... ๐Ÿ˜‰
                Just played a little with the lightning and material settings, and below you can see the results made with Kerkythea...
                Cheers
                Kim Frederik
                Cheers
                Kim Frederik
                  mateo soletic
                  Great stuff Solo,thanks for sharing.
                  Concept Illustrations
                    Click Draw
                    Been trying to download the file from the link, but it seems to automatically remove the zip extension and then says that it is not a SU file...?
                    How embarrassing...
                    Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                    • daleD Offline
                      dale
                      Same problem here
                      • soloS Offline
                        solo
                        ๐Ÿคฃ
                        You need to read just above the dowload:
                        Remember to remove the .skp and unzip attachment.
                        At the time (more than two years ago), it was not possible to post a .zip file, so it needed to be disguised as a .skp file.
                        • daleD Offline
                          dale
                          oops ๐Ÿ˜ณ
                            Click Draw
                            Here are a couple screen shots to show what I get.....(and stop laughing ๐Ÿ˜„ )
                              In Explorer, open up Folder Options
                              then go to the View tab,
                              then untick "Hide extensions for known file types"
                              Then you can rename "water_test.zip.skp" to "water_test.zip" and unzip it.
                              • soloS Offline
                                solo
                                OMG!!! ๐Ÿ˜ฎ
                                That's been downloaded over 1900 times, wish my garden pack could do that well.
                                  Click Draw
                                  Thanks Thomas...
                                  • daleD Offline
                                    dale
                                    @solo said:
                                    OMG!!! ๐Ÿ˜ฎ
                                    I think you may have something there. Things like water, paving, grass, ground cover are all usually the weak spots especially in renderings, maybe down the line you could develop the rendering weakspots.
                                    • daleD Offline
                                      dale
                                      On the mac highlite "water_test.zip.skp" by double clicking on it and delete the ".skp"
                                      (like I should have done before my earlier post) a dialogue box will come up confirming your choice.
                                        mateo soletic
                                        solo wrote:OMG!!! ๐Ÿ˜ฎ
                                        Free things always go better ๐Ÿ˜†
                                        I think you may have something there. Things like water, paving, grass, ground cover are all usually the weak spots especially in renderings, maybe down the line you could develop the rendering weak spots.
                                        I agree , average guy out there wants minimum effort with maximum possible results, minimal learning curve ,SketchUp is there for modeling but still there are weak spots in getting this final output right when rendering and post process is in question. I think there is a great potential market here.
                                          l.frisken
                                          how did you make it solo? what method did you use to create the ripples? I'm sure everyone would be interested to know!
