    Water with SU and render engine.
    extensions
    19 Posts 12 Posters 6.5k Views 12 Watching
    • FrederikF Offline
      Frederik
      @solo said:
      I rendered it with Podium, but believe that Kerkythea users can also use this model.
      Thanks for sharing, Pete! ๐Ÿ˜„
      Indeed users of Kerkythea can render this model... ๐Ÿ˜‰
      Just played a little with the lightning and material settings, and below you can see the results made with Kerkythea...
      Cheers
      Kim Frederik
      Cheers
      Kim Frederik
        mateo soletic
        Great stuff Solo,thanks for sharing.
        Concept Illustrations
          Click Draw
          Been trying to download the file from the link, but it seems to automatically remove the zip extension and then says that it is not a SU file...?
          How embarrassing...
          Have I mentioned how much of a laugh I get out of some of the Signatures on here!
          • daleD Offline
            dale
            Same problem here
            • soloS Offline
              ๐Ÿคฃ
              You need to read just above the dowload:
              Remember to remove the .skp and unzip attachment.
              At the time (more than two years ago), it was not possible to post a .zip file, so it needed to be disguised as a .skp file.
              • daleD Offline
                dale
                oops ๐Ÿ˜ณ
                  Click Draw
                  Here are a couple screen shots to show what I get.....(and stop laughing ๐Ÿ˜„ )
                    In Explorer, open up Folder Options
                    then go to the View tab,
                    then untick "Hide extensions for known file types"
                    Then you can rename "water_test.zip.skp" to "water_test.zip" and unzip it.
                    • soloS Offline
                      OMG!!! ๐Ÿ˜ฎ
                      That's been downloaded over 1900 times, wish my garden pack could do that well.
                        Click Draw
                        Thanks Thomas...
                        • daleD Offline
                          dale
                          @solo said:
                          OMG!!! ๐Ÿ˜ฎ
                          I think you may have something there. Things like water, paving, grass, ground cover are all usually the weak spots especially in renderings, maybe down the line you could develop the rendering weakspots.
                          • daleD Offline
                            dale
                            On the mac highlite "water_test.zip.skp" by double clicking on it and delete the ".skp"
                            (like I should have done before my earlier post) a dialogue box will come up confirming your choice.
                              mateo soletic
                              solo wrote:OMG!!! ๐Ÿ˜ฎ
                              Free things always go better ๐Ÿ˜†
                              I think you may have something there. Things like water, paving, grass, ground cover are all usually the weak spots especially in renderings, maybe down the line you could develop the rendering weak spots.
                              I agree , average guy out there wants minimum effort with maximum possible results, minimal learning curve ,SketchUp is there for modeling but still there are weak spots in getting this final output right when rendering and post process is in question. I think there is a great potential market here.
                                l.frisken
                                how did you make it solo? what method did you use to create the ripples? I'm sure everyone would be interested to know!
