    Modlumi - Easy 3D modelling
    388 Posts 9 Posters 57.5k Views 9 Watching
      so...10 seconds! πŸ™‚
      Reply Quote 2
        Request : option for keep or not the previous one extrude drawing : so if extrude a box's face you will have 2 boxes! (Generally with Ctrl)
        (if you Extrude the Blue section following you will have a box rectangle drawn πŸ™‚
        Bug File linked : impossible to Extrude this face! (v 0.25)
        I can Push it!
        other faces are well puspulled!
        bug127.zip
          @pixelcruncher
          On the Net it's the 0.26
          On your direct link here and in your site it's the 0.25 ?
          • pixelcruncherP
            pixelcruncher Extension Creator @pilou
            @pilou Oops, thanks for the heads up. Will fix it.
            • majidM
              majid @pilou
              @pilou Yes, and it works on a 'softened" curved surface at once as well. So maybe a joint-push-pull over a curved surface would be nice as well, sort of "Solidify" as in Blender, maybe.
                @majid
                Yep but curious i don't find the same for the "no jointed" extruded mode! πŸ™‚
                  • KrassK
                    Krass
                    alors Γ§a ! Qui eut cru que l'Ia aurait gΓ©nΓ©rΓ© du Gaudi depuis ta 3D ...
                      BΓ© si, rien ne les arrΓͺte! πŸ™‚
                      Il suffit de leur demander! 😊
                      • ntxdaveN
                        ntxdave @pilou
                        Now I have another issue I want to share with everyone. I may be doing something wrong, but I think there is a problem with the section plane function. If you look at the image below, I think you will see the issue. If I create just a standard cube (or some type of model that does not have thickness to the faces). I do not think it is always creating the section cut correctly. Again, just IMO.
                        Press F1...thank me later
                        • KrassK
                          Krass
                          This post is deleted!
                          • KrassK
                            Krass
                            In the meantime, you need to group your vertical walls, and that works.
                            modlumi_hPCYqoZKu8.mp4
                            ntxdaveN 1 Reply Last reply
                            • ntxdaveN
                              ntxdave @Krass
                              Yes, I messed up on the example 2. Actually, 1 is the real problem to me. I think you should be able to see inside the cube.
                                  • KrassK
                                    Krass
                                    Hello Thomas,
                                    if I try to import this skp model I get this error message
                                    Here is th model: https://www.swisstransfer.com/dl/01a1c470-3f4d-73e6-90e9-0c7fc5fdc0f1
                                    Mike AmosM 1 Reply Last reply
                                    • ntxdaveN
                                      ntxdave
                                      Just curious, are there any plans in the future to combine Modlumi and Rayscaper?
                                      • KrassK
                                        Krass
                                        • ntxdaveN
                                          ntxdave @Krass
                                          πŸ‘πŸ‘πŸ‘
                                            Mike Amos @Krass
                                            @Krass said:
                                            Hello Thomas,
                                            I can confirm that finding.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 19 / 20
