    Modlumi - Easy 3D modelling
    384 Posts 9 Posters 53.9k Views 9 Watching
    • pixelcruncherP
      @pilou Thanks for testing 0.21 so quickly! πŸ™‚
      I think I found the Rotate problem from your last picture, but I want to be sure we are talking about the same thing. Here is what I see:
      1. Select the rectangle and start Rotate (Q).
      2. Lock the green axis with the Left arrow.
      3. Hold Shift, then move to the corner of the rectangle. It shows Endpoint.
      4. Click. The center looks like it is on the corner...
      5. ...but when you orbit, you see that the center is not on the corner. Without Shift, it is on the corner.
      Is this your problem? Two short questions:
      • Do you hold Shift when you click the center? If not, which keys do you press, and in which order?
      • "The locked axis doesn't work as expected": which line did you want to rotate around? Is it the green line in your picture, or an edge of the rectangle?
      A small GIF of your steps would help a lot. πŸ™‚
      Cheers,
      Thomas
        Ok that was that : i used Shift like in SketchUp for block the plane! πŸ™‚
        Now with your Down Arrow that works like a charm! πŸ™‚ Bravo
        And the Perpendicular works also fine in this case!
          My STL armchair won't works as you said few seconds... never successed from now...
          Maybe i make an error in the process ?
          I see the logo Preparing your Model but...
          I will try again! πŸ™‚
          Edit No definitly not in mm
          but yes in meters and yes in seconds! πŸ™‚ (with merge not enabled)
          I will test in merging coplanar faces! πŸ™‚ No success in reasonable time!
          Ps It's better for your prog to have "quads" volumes subdivided for import ?
          Not sure it's raisonable to work with this sort of thing! πŸ™‚
            With your trick of the arrows that works fine! πŸ™‚
            ntxdaveN 1 Reply Last reply
              Scenes are very cool and works pefectely!
              Request
              Does it possible to have scenes who keep transformations during the time line ?
              A volume is not chamfered during scene 1 to 10, then chamfered 10 to 20 etc...GIF_scene1.gif
              • ntxdaveN
                ntxdave @pilou
                How do you do stuff like this?
                Press F1...thank me later
                • chonC
                  chon @pixelcruncher
                  @pixelcruncher a dit:
                  @chon The installed modlumi.exe is a single file...
                  @pixelcruncher Many thanks.
                  I installed it on a USB key and ran the exe. It works fine but a folder is created in C:\Users\User\AppData\Local, so it is not a pure standalone install.
                  πŸ˜‰
                  SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
                  • pixelcruncherP
                    pixelcruncher Extension Creator @chon
                    @chon Would it help if I would make the app data user configurable, or have the option to start it with --app-data such that you can store the data on USB disk as well?
                    chonC 1 Reply Last reply
                      @pixelcruncher
                      You have not Save as or Export SKP ?
                      • pixelcruncherP
                        @pilou
                        I will add "Save As...".
                        I'm not adding SKP export. This is the exact feature that got IngeTrazo in trouble with Trimble: https://github.com/ingelibre/ingetrazo/commit/fb3ceab1656e0b3dcd347e05f794157a8cffb66c - I'm steering clear of that.
                          @ntxdave
                          The How To πŸ˜‰
                          Make the module as show on the gif head post above
                          Select the 3 or 5 segments of the little top roof!
                          Apply a Fillet (here 3)
                          Then Maket it as Group or Component
                          And then use as you want the Move Rotation / Copy
                          with the % πŸ˜‰ three or four time
                          (make group apply copy rotation % etc...)
                          New in Modlumi: copy arrays with progressive scaling You can now combine Move or Rotate with Copy and scaling to create progressively smaller or larger copie...
                          sketchucation (community.sketchucation.com)
                          Here 5 segments of the little top roof was filletered!
                          Then take a snaphot or save to image inside Modlumi itself
                          Send the image to Gemini with any prompt you want!
                          Mine was : Effacer les axes, remplacer chaque volume par une carcasse de voiture, et mettre le rΓ©sultat dans la nature
                          "Erase the axes, replace each volume with a car carcass, and place the result in a natural setting."
                          All take less time than me to write this post! πŸ™‚
                          1 Reply Last reply β™₯
                            @pixelcruncher
                            About SKP you right! πŸ™‚ Keep simple!
                            And Dae ?
                            Or the GlTF is sufficient ? (for SU) without juridic problems)
                            • chonC
                              chon @pixelcruncher
                              Mayby, i don't know. Sorry, i'm just a poor user πŸ˜‹
                              Here are the 4 elements in the C:\Users\User\AppData\Local\modlumi folder after my first use :
                              analytics.txt
                              modlumi.log
                              plugins (folder)
                              imgui.ini
                              The installer made also an alias of modlumi in the windows start menu.
                              Hope it can help
                              • pixelcruncherP
                                pixelcruncher Extension Creator @pilou
                                @pilou Thanks for testing the armchair again! I'm looking into why it never finishes in millimeters or with Merge coplanar faces; in meters it should still come in within seconds.
                                It is a heavy one, though: over a million triangles for one chair. A chair modelled by hand is usually a few thousand. You said Krea 3D made it: does Krea have an option to export with less detail, or a lower polygon count? Something around 50,000 triangles would keep the shape and be much easier to work with in Modlumi or in SketchUp.
                                About quads: no need to subdivide before importing. Modlumi takes triangles or quads, and fewer polygons are always faster.
                                Cheers,
                                Thomas
                                • ntxdaveN
                                  ntxdave
                                  Really silly question: How do you draw guides in Modlumi?
                                  • ntxdaveN
                                    ntxdave
                                    @pixelcruncher Would it be possible for you so support using the Windows (or Mac) native fonts for the 3D Text and Text labels?
                                    • pixelcruncherP
                                      Modlumi 0.22 is out
                                      Download it for Windows from https://modlumi.com/download/latest/windows, or open the browser version at https://modlumi.com/app/. If you already run 0.21 on Windows, it will offer you the update. The Mac build of 0.22 will follow later.
                                      New features
                                      • A library of free materials. The Materials panel has a new Library tab with 27 materials: brick, stone, wood, roof tiles, grass and more. Click one to download it; the desktop app keeps it, so it works offline afterwards. Each material shows where it comes from and its license. https://modlumi.com/docs/user-guide/materials/#library-materials
                                      • Share materials as files. Right-click a material and choose Export material... to save it as a .mlmat file. Import material... reads .mlmat files and SketchUp .skm materials. https://modlumi.com/docs/user-guide/materials/#share-materials
                                      • Scenes swing around the model instead of passing through it. Clicking or playing a scene now orbits the camera around the model. In Window β†’ Model Settings you can choose Orbit or Straight, and set the glide and pause times. https://modlumi.com/docs/user-guide/navigating/#how-the-camera-moves-between-scenes
                                      Improvements
                                      • Delete materials, or remove every material nothing uses. Right-click a material in the Materials panel and choose Delete, or click Remove Unused next to the material count. Both can be undone. Thanks @ntxdave! https://modlumi.com/docs/user-guide/materials/#delete-a-material
                                      • Move screen text labels with the Move tool, and double-click a label to change its wording. Press M, click the label, then click where it should go. With Select, double-clicking a label or a dimension puts its text in Properties, ready to type over. Thanks again @ntxdave! https://modlumi.com/docs/user-guide/annotating/#text
                                      • Show or hide the drawing axes with View β†’ Axes. It only changes the view, not the model. Thanks @pilou for asking!
                                      • Imported STL meshes look smooth instead of faceted. STL files, and OBJ or PLY files without shading, now soften the edges between faces that meet at a gentle angle: 25 degrees by default, and you can change it in the import options. https://modlumi.com/docs/user-guide/files/#other-3d-formats
                                      • Run Modlumi from a USB stick. Start modlumi.exe with --app-data and a folder, and it keeps your settings, layout and plugins in that folder instead of on the computer. The user guide has a small launcher script to put on the stick. Thanks @chon for the idea! https://modlumi.com/docs/user-guide/installing/#run-modlumi-from-a-usb-stick
                                      • Modlumi reopens the panels that were open when you closed it. Properties, Materials, Outliner, Scenes and Layers come back where they were docked. Thanks to whoever asked through the feedback form!
                                      Fixes
                                      • Rotate's center lands exactly on the point you snap to, also while you hold Shift to keep the plane. Before, the center could end up off the corner you clicked, sometimes far behind it. @pilou, this is the problem from your sloped face; let me know if it works for you now.
                                      • Model Settings shows Use for New Models right below the unit fields. In a short window the button was cut off, so it was easy to miss that new models can keep your units. Thanks to the user who reported it from the app!
                                      Full release notes: https://modlumi.com/docs/release-notes/
                                      Thanks for all the reports. Keep them coming!
                                      Cheers,
                                      Thomas
                                        @pixelcruncher
                                        About the Slope surface and Copy Rotation who was resolved but use of down Arrow
                                        It 's working also fine now with the use of Shift for block the protractor from a face!
                                        And the Snap points are now well picked!
                                        I can't choice numbers of facettes in Krea 3D! 😞
                                        So i will use the https://stephaneginier.com/sculptgl/
                                        who is a cool Zbrushlike but has also COOL TOOLS!
                                        How it works: Import your file (Files > Import (obj, sgl, ply, stl)), then go to the Topology menu (on the right) and use the Remesh or adjust resolution option.
                                        Strong points: Runs entirely in your browser (WebGPU/WebGL), very efficient for viewing the mesh live.
                                        Kill some faces during the decimation!
                                        File is too big must < 50 Megas! For these 2 ones!
                                        https://3d-convert.com/
                                        https://www.meshconvert.com/
                                        So MeshLab
                                        Here the MeshLab file (580 000 faces)
                                        https://moiscript.weebly.com/uploads/3/9/3/8/3938813/output_lab.zip
                                        ModLumi
                                        When process of importation is finished (23 seconds) on my very old Latop (more 13 years) click it on the origine!
                                        Millimeters enabled
                                        30 seconds again for finish the process of display!
                                        Very tiny but you can resize it! Use mouse wheel first before Menu Zoom Extend...
                                        • ntxdaveN
                                          ntxdave
                                          Just tried something with 0.22 and had a problem. I created 4 scenes and had a Text object for each of the 4 scenes. I then used the Layers feature to control what text object was to be shown with each scene. I went through each of the 4 scenes and selected the text object I wanted to be part of the scene and then clicked the Update button for each of the scenes. However, when view/play each of the scenes it is ignoring the layers, I have turned on for each of the scenes to show which scene is being viewed, the layers control for the scenes is not controlling the text object that should be show in each of the scenes.
                                          Maybe I am doing something wrong or there is a bug in controlling what is visible in each of the scene.
                                          I tried to send the Modlumi file but the forum would not allow me to send/attach it.
                                          The bug reporter should also allow you to attach Modlumi file.
                                            @pixelcruncher
                                            Cool for hide axes for snapshot screen : my prompt will be smaller! πŸ™‚
                                            For any reason , axes by default are not on the middle of the screen! ???
                                            (even you close the Properties pannel!
                                            Lines are now of the colors axes when parallel of the axes!
                                            Request : Extrude Line(s) (very useful) !
                                            @ntxdave You draw Guides with Measure (T) (not Dimension πŸ˜‰
                                            Draw them from a line (segment) and Enter a measure!
                                            pixelcruncherP ntxdaveN 2 Replies Last reply
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 19
                                            • 20
                                            • 14 / 20
