    Modlumi - Easy 3D modelling
    276 Posts 9 Posters 24.0k Views 7 Watching
    • pixelcruncherP
      @pilou Thanks for testing 0.21 so quickly! πŸ™‚
      I think I found the Rotate problem from your last picture, but I want to be sure we are talking about the same thing. Here is what I see:
      1. Select the rectangle and start Rotate (Q).
      2. Lock the green axis with the Left arrow.
      3. Hold Shift, then move to the corner of the rectangle. It shows Endpoint.
      4. Click. The center looks like it is on the corner...
      5. ...but when you orbit, you see that the center is not on the corner. Without Shift, it is on the corner.
      Is this your problem? Two short questions:
      • Do you hold Shift when you click the center? If not, which keys do you press, and in which order?
      • "The locked axis doesn't work as expected": which line did you want to rotate around? Is it the green line in your picture, or an edge of the rectangle?
      A small GIF of your steps would help a lot. πŸ™‚
      Cheers,
      Thomas
        Ok that was that : i used Shift like in SketchUp for block the plane! πŸ™‚
        Now with your Down Arrow that works like a charm! πŸ™‚ Bravo
        And the Perpendicular works also fine in this case!
          My STL armchair won't works as you said few seconds... never successed from now...
          Maybe i make an error in the process ?
          I see the logo Preparing your Model but...
          I will try again! πŸ™‚
          Edit No definitly not in mm
          but yes in meters and yes in seconds! πŸ™‚ (with merge not enabled)
          I will test in merging coplanar faces! πŸ™‚ No success in reasonable time!
          Ps It's better for your prog to have "quads" volumes subdivided for import ?
          Not sure it's raisonable to work with this sort of thing! πŸ™‚
            With your trick of the arrows that works fine! πŸ™‚
            ntxdaveN 1 Reply Last reply
              Scenes are very cool and works pefectely!
              Request
              Does it possible to have scenes who keep transformations during the time line ?
              A volume is not chamfered during scene 1 to 10, then chamfered 10 to 20 etc...GIF_scene1.gif
              • ntxdaveN
                ntxdave @pilou
                How do you do stuff like this?
                Press F1...thank me later
                • chonC
                  chon @pixelcruncher
                  @pixelcruncher a dit:
                  @chon The installed modlumi.exe is a single file...
                  @pixelcruncher Many thanks.
                  I installed it on a USB key and ran the exe. It works fine but a folder is created in C:\Users\User\AppData\Local, so it is not a pure standalone install.
                  πŸ˜‰
                  SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
                  • pixelcruncherP
                    pixelcruncher Extension Creator @chon
                    @chon Would it help if I would make the app data user configurable, or have the option to start it with --app-data such that you can store the data on USB disk as well?
                    chonC 1 Reply Last reply
                      @pixelcruncher
                      You have not Save as or Export SKP ?
                      • pixelcruncherP
                        @pilou
                        I will add "Save As...".
                        I'm not adding SKP export. This is the exact feature that got IngeTrazo in trouble with Trimble: https://github.com/ingelibre/ingetrazo/commit/fb3ceab1656e0b3dcd347e05f794157a8cffb66c - I'm steering clear of that.
                          @ntxdave
                          The How To πŸ˜‰
                          Make the module as show on the gif head post above
                          Select the 3 or 5 segments of the little top roof!
                          Apply a Fillet (here 3)
                          Then Maket it as Group or Component
                          And then use as you want the Move Rotation / Copy
                          with the % πŸ˜‰ three or four time
                          (make group apply copy rotation % etc...)
                          New in Modlumi: copy arrays with progressive scaling You can now combine Move or Rotate with Copy and scaling to create progressively smaller or larger copie...
                          sketchucation (community.sketchucation.com)
                          Here 5 segments of the little top roof was filletered!
                          Then take a snaphot or save to image inside Modlumi itself
                          Send the image to Gemini with any prompt you want!
                          Mine was : Effacer les axes, remplacer chaque volume par une carcasse de voiture, et mettre le rΓ©sultat dans la nature
                          "Erase the axes, replace each volume with a car carcass, and place the result in a natural setting."
                          All take less time than me to write this post! πŸ™‚
                          1 Reply Last reply β™₯
                            @pixelcruncher
                            About SKP you right! πŸ™‚ Keep simple!
                            And Dae ?
                            Or the GlTF is sufficient ? (for SU) without juridic problems)
                            • chonC
                              chon @pixelcruncher
                              Mayby, i don't know. Sorry, i'm just a poor user πŸ˜‹
                              Here are the 4 elements in the C:\Users\User\AppData\Local\modlumi folder after my first use :
                              analytics.txt
                              modlumi.log
                              plugins (folder)
                              imgui.ini
                              The installer made also an alias of modlumi in the windows start menu.
                              Hope it can help
                              • pixelcruncherP
                                pixelcruncher Extension Creator @pilou
                                @pilou Thanks for testing the armchair again! I'm looking into why it never finishes in millimeters or with Merge coplanar faces; in meters it should still come in within seconds.
                                It is a heavy one, though: over a million triangles for one chair. A chair modelled by hand is usually a few thousand. You said Krea 3D made it: does Krea have an option to export with less detail, or a lower polygon count? Something around 50,000 triangles would keep the shape and be much easier to work with in Modlumi or in SketchUp.
                                About quads: no need to subdivide before importing. Modlumi takes triangles or quads, and fewer polygons are always faster.
                                Cheers,
                                Thomas
                                • ntxdaveN
                                  ntxdave
                                  Really silly question: How do you draw guides in Modlumi?
                                  • ntxdaveN
                                    ntxdave
                                    @pixelcruncher Would it be possible for you so support using the Windows (or Mac) native fonts for the 3D Text and Text labels?
                                    • 11
                                    • 12
                                    • 13
                                    • 14
                                    • 14 / 14
