Modlumi - Easy 3D modelling
@pilou Thanks for testing 0.21 so quickly!
I think I found the Rotate problem from your last picture, but I want to be sure we are talking about the same thing. Here is what I see:
- Select the rectangle and start Rotate (Q).
- Lock the green axis with the Left arrow.
- Hold Shift, then move to the corner of the rectangle. It shows Endpoint.
- Click. The center looks like it is on the corner...
- ...but when you orbit, you see that the center is not on the corner. Without Shift, it is on the corner.
Is this your problem? Two short questions:
- Do you hold Shift when you click the center? If not, which keys do you press, and in which order?
- "The locked axis doesn't work as expected": which line did you want to rotate around? Is it the green line in your picture, or an edge of the rectangle?
A small GIF of your steps would help a lot.
Cheers,
Thomas -
Ok that was that : i used Shift like in SketchUp for block the plane!
Now with your Down Arrow that works like a charm!
Bravo
And the Perpendicular works also fine in this case!
My STL armchair won't works as you said few seconds... never successed from now...
Maybe i make an error in the process ?
I see the logo Preparing your Model but...
I will try again!
Edit No definitly not in mm
but yes in meters and yes in seconds!
(with merge not enabled)
I will test in merging coplanar faces!
No success in reasonable time!Ps It's better for your prog to have "quads" volumes subdivided for import ?
Not sure it's raisonable to work with this sort of thing!
With your trick of the arrows that works fine!
Scenes are very cool and works pefectely!
Request
Does it possible to have scenes who keep transformations during the time line ?
A volume is not chamfered during scene 1 to 10, then chamfered 10 to 20 etc...
@chon The installed modlumi.exe is a single file...
@pixelcruncher Many thanks.
I installed it on a USB key and ran the exe. It works fine but a folder is created in C:\Users\User\AppData\Local, so it is not a pure standalone install.
@chon Would it help if I would make the app data user configurable, or have the option to start it with
--app-datasuch that you can store the data on USB disk as well? -
@pixelcruncher
You have not Save as or Export SKP ? -
I will add "Save As...".
I'm not adding SKP export. This is the exact feature that got IngeTrazo in trouble with Trimble: https://github.com/ingelibre/ingetrazo/commit/fb3ceab1656e0b3dcd347e05f794157a8cffb66c - I'm steering clear of that.
@ntxdave
The How To
Make the module as show on the gif head post above
Select the 3 segments of the little top roof!
Apply a Fillet
Then Maket it as Group or Component
And then use as you want the Move Rotation / Copy
with the %
three or four time
(make group apply copy rotation % etc...)
New in Modlumi: copy arrays with progressive scaling You can now combine Move or Rotate with Copy and scaling to create progressively smaller or larger copie...
sketchucation (community.sketchucation.com)
Then take a snaphot or save to image inside Modlumi itself
Send the image to Gemini with any prompt you want!Mine was : Effacer les axes, remplacer chaque volume par une carcasse de voiture, et mettre le rΓ©sultat dans la nature
"Erase the axes, replace each volume with a car carcass, and place the result in a natural setting."
All take less time than me to write write this post!
@pixelcruncher
About SKP you right!
Keep simple!And Dae ?
