    Startup-crash when using Libfredo6-v15.8e-15-feb-26
    3 Posts 3 Posters 332 Views 3 Watching
    • D
      dukehh Newcomers
      Re: [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
      i encounter a start-problem of sketchup. it shows preferences or last files. choosing any crashes sketchup without message. starting from file-explorer to open a .skp-file works. i deleted all of my extensions and found out that it crashes when LibFredov-15.8e is installed. Does anyone have an idea? My Rubny-console:
      Fredo6 Plugins Information on 2026-03-03 13:31:19 +0100
      • Platform: arm64-darwin - Ruby: 3.2.2
      • Sketchup: 26.1.188
      • LibFredo6: v15.8e
      • LibFredo6 Binary loaded
      • Sketchucation ExtensionStore: 5.0.6
      • SCFLicense: v7.1a - 72
      • Fredo6 Plugins
      • SCFLicense directory present
        Signature File: 2025-03-31 14:06:11 +0200
        Curviloft: 2025-12-03 20:19:17 +0100
        Curvizard: 2025-10-11 12:38:52 +0200
        FredoScale: 2025-12-03 20:19:13 +0100
        JointPushPull: 2025-03-31 14:20:26 +0200
        RoundCorner: 2025-12-03 20:19:22 +0100
        ToolsOnSurface: 2025-12-03 20:19:08 +0100
        TopoShaper: 2023-10-25 19:42:08 +0200
        VisuHole: 2025-12-03 20:20:35 +0100
      I also deleted all the licensed extensions
      thanks for helping
        If it is crashing with Libfredo installed how are you running Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support command?
        Or is it crashing if you double click a .skp to launch SketchUp?
        • TIGT
          What are 'the error messages' ?
          A BugSplat or something else ?
          What is your MAC OS ?
          Select its icon and right-click > context-menu > Run as administrator.
          A dialog opens, when prompted choose Repair.
          This will fix any incorrect permissions etc that can cause unpredictable issue.
          Restart SketchUp to see if anything has improved.
          Repair will not affect any customization.
          Double-clicking
