    TIG Weld Shortcut Setting
    10 Posts 3 Posters 409 Views 3 Watching
    • ntxdaveN Offline
      ntxdave
      I use TIG Weld fairly often lately. I would like to assign a shortcut setting for it. Is there a way to do that (I have to admit that I have not tried)?
      Press F1...thank me later
        Sure. I use W for it.
        • ntxdaveN Offline
          ntxdave
          I wound up doing the same thing. I wanted to make it Ctrl+W but could not get it to work.
          • ntxdaveN Offline
            ntxdave @ntxdave
            Can someone tell me how to add the Ctrl as part of a shortcut? I have tried several time and cannot get it or the Alt key to work. I thought the Help file said you can these two keys.
              Hold CTRL and with it held press and release W.
                @ntxdave said in TIG Weld Shortcut Setting:
                You can use Ctrl and Alt for some keyboard shortcuts. Also Shift. But you can't assign keyboard shortcuts that are assigned by the operating system. Ctrl+A, Ctrl+C, Ctrl+V, for example are hard coded so you cannot assign them to other things in SketchUp.
                • ntxdaveN Offline
                  ntxdave @Dave R
                  @Dave-R This is what I tried but when I click on the Ctrl key nothing shows up. I will try @Rich-O-Brien’s approach as well. At this point I am just trying to get the Ctrl and/or Alt key to work for this/or other shortcuts in the future.
                  With some of my silly post lately, I am feeling really dumb and brand new to SketchUp. 🫠
                    Dave R @ntxdave
                    It's not a different approach. I just demonstrated what Rich wrote.
                    You're starting to worry me Dave.
                    • ntxdaveN Offline
                      ntxdave @Dave R
                      @Dave-R Sorry, I guess I misunderstood what you meant with your post. Yes, it works fine for me now.
                      Again, thanks to the two of you, I have learned something again.
                      One last issue I am having. I am trying to draw a heart that I want to have some "depth" to and have rounded sides. I can draw the hart (and Tig Weld the shape) but some problems with the top dip joint when I try to use the Follow Me tool. I have done it before but just having some trouble getting a "good" shape.
                      Again, I want the two of you guys to know how much I appreciate your assistance and patience. It is greatly appreciated..
                      • ntxdaveN Offline
                        ntxdave @ntxdave
                        Making some progress. πŸ‘ πŸ‘ πŸ‘
