    help with a thread
    40 Posts 3 Posters 4.7k Views 3 Watching
      Leggy
      hi guys I've been experimenting with the helix tool for making threads with a bit of success, but I'm trying to draw a internal trapezoidal thread ( diagram 150mm, pitch 2.7 mm, depth 1.3mm , 20mm high)
      could any one help with a walk through on how to do this
        Leggy
        I took a body filler squeeze of the thread as you can see here
          Model in meters to avoid issues with faces below 1mm. Afterwards scale it down to correct dimensions.
          If you are using Helix Along Curve you are 90% there.
          If you have CurviLoft you can use Loft Along Path to extrude the profiles.
            Leggy
            unfortunately not that much success, can you do a run through of how you did that
              Rich O Brien Moderator @Leggy
              @Leggy said in help with a thread:
              Try sharing a file because I honestly can't make much sense of your dimensions.
              A 150mm [diameter?] with a 20mm height seems wrong.
                Leggy
                its a screw on cap, the dimensions are correct
                  Leggy
                  if you look at the pictures I posted you can see the height of the thread
                    Dave R @Leggy
                    pitch 2.7 mm
                    I expect your first problem is you are measuring the pitch incorrectly. From your images it looks like the pitch is closer to 5mm.
                    So far you haven't told us what your actual problem is in modeling these threads. I've shown you before how to model screw threads. The process is the same with these. Start with a helix and profile. Use Upright Extruder.
                    The method Rich described will work fine, too.
                      Are you trying to model a cap or the neck of the container? What is it exactly? I've been trying to find real specifications for the threads on screw top containers but based on what little information you've provided, it's been a waste of time.
                        Leggy
                        this thread is a weird one . its on an Italian built mega yacht. its a 150mm diameter aluminum tube with a 20mm high thread on the end. the tube holds a retractable electric cable for shore plug in, when at sea the cable is retracted and the cap I have to make screws on the top to keep the water out
                        I"ll get some more info on the thread
                          Leggy
                          here is the profile and my measurements, there are only 4 crests on the thread
                          hope this helps
                            Leggy
                            with a 150mm diameter
                              So what's your problem in trying to model it in SketchUp? What's not working?
                              When you model it make it 2 or 3 turns longer so you can cut the extrusion off nicely.
                                Leggy
                                I’m the problem, ha ha
                                I need a back to basics tutorial, I always seem to miss a certain point and nothing happens . I can see the way both of you do the threads but I’m missing something
                                  Leggy
                                    Leggy
                                    ok , after watching Rich's video about 8 times I'm making progress. I was missing the upright extension
                                    what's curve origin? I set it to -1.5 as in the video, so that made the male thread , now to make the female which ill offset by 0.3
                                    Dave RD Rich O BrienR 2 Replies Last reply Reply Quote 0
                                      Dave R @Leggy
                                      OK. So you don't need the video tutorial I did? Good enough.
                                        Leggy @Dave R
                                        @Dave-R where is it?
                                          I did a video?
                                            Dave R @Leggy
                                            where is it?
                                            • 1 / 2
