    help with a thread
    40 Posts 3 Posters 6.1k Views 3 Watching
      Leggy
      its a screw on cap, the dimensions are correct
        Leggy
        if you look at the pictures I posted you can see the height of the thread
          Dave R @Leggy
          @Leggy said in help with a thread:
          pitch 2.7 mm
          I expect your first problem is you are measuring the pitch incorrectly. From your images it looks like the pitch is closer to 5mm.
          So far you haven't told us what your actual problem is in modeling these threads. I've shown you before how to model screw threads. The process is the same with these. Start with a helix and profile. Use Upright Extruder.
          The method Rich described will work fine, too.
            Are you trying to model a cap or the neck of the container? What is it exactly? I've been trying to find real specifications for the threads on screw top containers but based on what little information you've provided, it's been a waste of time.
              Leggy
              this thread is a weird one . its on an Italian built mega yacht. its a 150mm diameter aluminum tube with a 20mm high thread on the end. the tube holds a retractable electric cable for shore plug in, when at sea the cable is retracted and the cap I have to make screws on the top to keep the water out
              I"ll get some more info on the thread
                Leggy
                here is the profile and my measurements, there are only 4 crests on the thread
                hope this helps
                  Leggy
                  with a 150mm diameter
                    So what's your problem in trying to model it in SketchUp? What's not working?
                    When you model it make it 2 or 3 turns longer so you can cut the extrusion off nicely.
                      Leggy
                      I’m the problem, ha ha
                      I need a back to basics tutorial, I always seem to miss a certain point and nothing happens . I can see the way both of you do the threads but I’m missing something
                        Leggy
                          Leggy
                          ok , after watching Rich's video about 8 times I'm making progress. I was missing the upright extension
                          what's curve origin? I set it to -1.5 as in the video, so that made the male thread , now to make the female which ill offset by 0.3
                          Dave RD Rich O BrienR 2 Replies Last reply Reply Quote 0
                            Dave R @Leggy
                            OK. So you don't need the video tutorial I did? Good enough.
                              Leggy @Dave R
                              @Dave-R where is it?
                                Rich O Brien Moderator @Leggy
                                I did a video?
                                  Dave R @Leggy
                                  where is it?
                                    Leggy
                                    Aha I got you mixed up, that was the one I watched
                                      Leggy
                                        Leggy
                                        Ok I’ve managed a male and female thread on a 150mm diameter, with a 0.3 offset, . It’s very tight can wind it on for 2 threads , and that’s it. Tomorrow doing another female with an extra 0.3 clearance on all faces, so see how that goes. I think it’s the shrinkage on the printer that’s causing the problem
                                        Thanks Guys for all your help
                                          Dave R @Leggy
                                          That's probably it. You'll have to work that out based on the material.
                                            Leggy
                                            I finally got it to work , pictures to follow , thanks Guys
