    Rayscaper Hotrod (Ford Model A)
    11 Posts 3 Posters 661 Views 3 Watching
      A good HDRI for car renders, used it many times. For some reason the flames in V1 are given a emiter quality it was not given and in any case the transparency does not come across as yet. SHadow catcher for the HDRI which is just a plane not up either but shadows not apparent without. Future releases perhaps or a workaround.
      Not done very much but aswsign a few texture finishes, lighting exposure to come as will a few lights.
        Mike Amos @Mike Amos
        Post pro exposure change to .30.2 1000s  2086 X 1024 01m 38s GPU Exposure .30 Post.png
        • tuna1957T Offline
          tuna1957
          Good progress on the hot rod. Hope you can get the flame issue figured out. 👍
            Ta mate. Always forwards.
            • P Online
              @Mike-Amos
              Nice, an excellent start! I would put some lights on that beauty.
              I added the alpha issue to my bugs list—it's not forgotten! You can try cleaning that alpha channel with a tool like Affinity Photo as a workaround.
              Note that you can update exposure in Rayscaper if you'd like:
              Cheers,
              Thomas
              • P Online
                I'm not following this @Mike-Amos
                  OK, the ground plane I inserted is showing up now, I post pro'd the exposure to 2.25.
                    Still finding scaling issues for the HDRI and a method of implementing a shadow catcher. Also, the flame still has an illumination quality I did not apply.
                      The issues I have seen in Rayscaper and PNG transparencies seems to be entirely to do with quality of the image. The only pending item is the illumination which occurs without user input.
                      This site has some great transparencies btw. https://www.cleanpng.com/png-realistic-fire-flames-illustration-8333208/download-png.html
                        As you can see the HDRI does not level with the model and the attempt at a shadow catcher is well off. Encouraged by the flame mostly working and the headlights being fair too. I still need to sort out scaling of the hdri but had this issue before so not a Rayscaper issue per se.
                        tuna1957T 1 Reply Last reply Reply Quote 1
                        • tuna1957T Offline
                          tuna1957 @Mike Amos
                          @Mike-Amos Hope you get things sorted out. I’ve had the same weird scaling issues with probably half my hdr’s and spherical jpeg’s.
                          • P pixelcruncher referenced this topic on
