    problem with libfredo6
    6 Posts 3 Posters 115 Views 3 Watching
    • H Offline
      hamsalah
      i have problem with libfredo6 it wont install i dont know why i keeping install and uninstall it
      https://i.epvpimg.com/xpoGdab.jpg
      https://epvpimg.com/eekOdab.jpg
      https://i.epvpimg.com/jsvqeab.jpg
        Install latest version: https://sketchucation.com/pluginstore?pln=LibFredo6
        Where did you even get v1? Its v15 you need
        • H Offline
          hamsalah
          i have already installing the latest version but the same problem
          i tried to install in in another computer and it works
          but on my laptop wont work
          TIGT 1 Reply Last reply Reply Quote 0
            Please look at the 2nd image you shared. It says v1.0
            Libfredo version 15
            • H Offline
              hamsalah
              yeah thats the problem although i installed the 15.0a version
              it says v1.0 i dont know whats the problem is
              and the author name dont show
                TIG Moderator @hamsalah
                @hamsalah
                As well as the weirdness of you having installed v1 rather than v15 [firstly, please install the latest one !], the SketchUp error message you provided shows a number of problems loading several other extensions as SketchUp starts - including those which ship with SketchUp and should be auto-copied over to your user's Plugins folder as SketchUp first runs.
                If SketchUp was not installed properly it can result in unexpected issues, often relating to folder/file permissions.
                You might sometimes muddle through unscathed, but I suspect this is the case here.
                Luckily it can often be fixed without uninstalling/reinstalling SketchUp or any of your extensions etc.
                Follow these steps.
                Close SketchUp.
                Find the SketchUp installer's exe file - usually found in your Downloads folder [if not download a new copy, or dig out your old one].
                Select the exe file's icon, right-click > context-menu > Run as administrator
                When prompted choose 'Repair'
                When it's finished restart SketchUp and see if the situation improves.
                Double-clicking an installer's exe file to 'Run' it is not the same thing, even if your user-account has admin powers.
