    Update Licenses
    8 Posts 3 Posters 273 Views 3 Watching
    • Gus RG Offline
      Gus R
      Is there an easy way to update my licenses for all my licensed products? Mostly Fredo. Rather than one at a time? I'm just rebuilding my system here and am still working on it.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
      • Gus RG Offline
        Gus R
        Getting an A0B error....
        Not related but here's the Sketchucation output.
        Fredo6 Plugins Information on 2025-02-07 07:49:38 -0700
        • Platform: x64-mswin64_140 - Ruby: 2.7.2
        • Sketchup: 22.0.354
        • LibFredo6: v15.0a
        • LibFredo6 Binary loaded
        • Sketchucation ExtensionStore: 4.4.1
        • SCFLicense: v6.4a - 74
        • Fredo6 Plugins
          Curviloft v2.0a
          Curvizard v2.5a
          ElevationProfile v1.1f
          FredoCorner v2.7a
          FredoScale v3.6a
          FredoSpline v2.6a
          FredoTools v4.5c
          HoverSelect v1.5a
          JointPushPull v4.8a
          MoveAlignMe v1.4a
          RoundCorner v3.4a
          ToolsOnSurface v2.6a
          TopoShaper v2.7a
          VisuHole v1.5a
        • SCFLicense directory present
          Signature File: 2022-03-17 16:44:16 -0600
          ClothWorks: 2023-03-02 11:31:00 -0700
          Curviloft: 2023-01-21 17:48:06 -0700
          Curvizard: 2022-03-31 21:36:49 -0600
          FredoScale: 2022-03-31 22:39:51 -0600
          FredoSpline: 2022-10-13 19:37:57 -0600
          JointPushPull: 2022-03-31 21:36:01 -0600
          RoundCorner: 2022-04-02 08:17:45 -0600
          ThruPaint: 2024-07-15 13:07:06 -0600
          ToolsOnSurface: 2022-03-31 21:42:23 -0600
          TopoShaper: 2022-03-31 21:38:52 -0600
          VisuHole: 2022-04-01 07:11:46 -0600
        • Gus RG Offline
          Gus R
          Got rid of the error. Deleted the signature file and re-started SU per Rich in another post. Works one by one.
            As soon as your device is seen as new then its manually activating that is needed.
            If you drag folders from a device to another device the the license will complain. Its a new environment and that means a new seat.
              That output suggests your are not licensed. Are you just moving folders?
              Trouble brewing methinks....
              • Gus RG Offline
                Gus R @Rich O Brien
                @Rich-O-Brien They're licensed. I fixed it. Now I have another issue. The dreaded "red out" templates file location.
                TIGT 1 Reply Last reply Reply Quote 0
                  TIG Moderator @Gus R
                  @Gus-R
                  All of your custom-templates must be located in a specific location.
                  Typically on a PC it's
                  C:\Users\YOURUSERNAME\AppData\Roaming\SketchUp\SketchUp 20nn\SketchUp\Templates
                  Where you add your own user-name and edit the nn to your current SketchUp version
                  Unlike other folder locations this path is not editable.
                  So does that folder exist ?
                  If not, then you need to make it, and ensure it has 'full' read/write' permissions etc.
                  Adjust your Preference settings accordingly.
                  • Gus RG Offline
                    Gus R @TIG
                    @TIG It was stuck with my old computer name. I had to get two new ssd's and a new Windows 10 Pro install. I reinstalled SU and everything was almost still there and everything was working fine. I re-associated the directories except for the templates which was stuck with the old name which was no longer present. That meant I kept getting a warning on SU start-up. So I created a dummy user directory with the old name and SU...templates and it took.
