    Can't update my Round Corner Trial
    6 Posts 3 Posters 242 Views 3 Watching
      Dougmcpeek1 Newcomers
      I downloaded round corner trial and loved it so I purchased the $50.00 package assuming that it would update the expiry on the trial version. Today I discovered that it did not update. I can not figure out how to upgrade the plugin. When I run the download it simply takes me to the Sketchup start screen from there I have tried to do many things with no success.
      Please help me.
        If you visit https://sketchucation.com/webshop/my-licences.php you can download your license file
        Instructions to activate are at: https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
        D 1 Reply Last reply Reply Quote 0
          Dougmcpeek1 Newcomers @Rich O Brien
          @Rich-O-Brien
          When I download the file and open it then It takes me directly to the front page of Sketchup. I can find no place with Sketchup to run the file It is downloading 4.4.1, is this correct
          TIGT 1 Reply Last reply Reply Quote 0
            It seems that I need to download LibFreido6 and upgrade it. Nothing I download with run and install program, it just takes me to Sketchup home screen. If I go into extension Manager there seem to be no place for me to run the update
              License files are activated in SketchUp using the License Dialog.
              Eg: Under the Tools > Fredo Collection > Round Corner > License... menu
              That will open a dialog with an Activate button. Click that and pick the .scflicense file for Round Corner
              • TIGT Online
                TIG Moderator @Dougmcpeek1
                @Dougmcpeek1
                When you download any license file you save it onto your computer, put it in a sensible location [like a subfolder in Documents]
                You do not 'open' it.
                Once it's on your computer you then need to validate it within SketchUp, under the Tools submenus for that extension.
                Extension RBZ files can be downloaded from our PluginStore and then installed using the Extensions > Extension Manager dialog's 'install' button.
                Save it onto your computer, do not try to open it - the install it.
                You will need to have the latestest SketchUcation toolset installed for the licensing, and additionally it also provides tools like Extensionstore³, which allow you to auto-install selected extensions from a dialog, sidestepping the RBZ download completely, and reminders for available updates, etc.
                With Fredo6's extensions you will also need his latest LibFredo6 installing - which is a library of helpers.
                After these installations restart SketchUp to sync everything.
                Then do the licensing.
