    How would you make this model possible?
    3 Posts 2 Posters 203 Views 2 Watching
      markpyvi
      Hi folks,
      Long time no see.
      Facing a problem or rather trying to gather ideas how to make a model of a tree included from 10cm rings welded side by side?
      As it will be rendered from distance only then easiest way I can think of is to make a simple 3d model, subdivide & texture it with fredos UV-tool.
      Just curious if there's a plugin that could help me doing it in proper 3d? Maybe some plugin tutorial hint?
      Cheers,
      • Rich O BrienR Rich O Brien moved this topic from Developers' Forum on
        I think you need to first generate a voronoi mesh then instance the ring.
        There used be an extension called TGI3D that had a type of surface generation that would be useful in this scenario.
        If you are limited to SketchUp then your approach of using a texture would be optimal. Especially if the object is to be viewed from distance.
        If you need actual geometry you could use Blender and it's Tissue addon to place a torus on every face
        Horses for courses
        M 1 Reply Last reply Reply Quote 0
          markpyvi @Rich O Brien
          Tnx Rich,
          as using Thea for rendering then just (for testing) made really simple model of tree trunk as Instance base & used "ring" model as instance & basically that's it. Probably have to play with thickness of instances & have to create a better base model to get the proper shape of tree but otherwise does the job good enough.
          My Q was pretty much for the interest if there's an easy way to do it in SU with any kind of plugins & from the point of getting smarter in SU. You're never too smart in SU, are you? πŸ˜„
          Will try those suggestions You offered as well just out of curious. Thanks for that πŸ™‚
          Cheers,
          Mark
