Can I save my work flow after close sketchup?
I don't know how to save my working sequence project after I change add some movements like car position or more. When I open skp model again it start over without any sequence.
Its embedded with the model so saving the model saves the animation data too.
But since its in beta expect odd behaviour. I find saving section of transformations as clips helps rather than saving huge amounts on transforms.
@Rich-O-Brien thank you but how can I reload my sequence?
@Rich-O-Brien Thank you. But may i know how can i reload sequence?
@Rich-O-Brien thank you sir but will everything in timeline reload also?
@DEPROKH said in Can I save my work flow after close sketchup?:
It should if you have saved the model. Its easy find out on your end by clicking the button.
If it doesn't I can't say why other than its Beta and strange things can happen
@Rich-O-Brien Thank you sir. I just find the solution, because I did not install sketchucation plugin. it's mean I need to install Lid.rbz and Sketchucation.rbz before using animator.
