    How to delete a post
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    6 Posts 3 Posters 302 Views 3 Watching
    • ntxdaveN
      ntxdave
      I made a post and had problems that kept asking me to refresh so I then made multiple posts to the same topic. I finally saw the thread with all of the duplicate posts. I then tried to delete the posts but still see them there although grayed out.
      What is the correct way to delete a post(s)?
      Press F1...thank me later
      • L
        Three little vertical dots on the lower right corner of the post click on the , hit delete on the drop down from 3 down
        ntxdaveN 1 Reply Last reply
        • Rich O BrienR Rich O Brien marked this topic as a question on
        • ntxdaveN
          ntxdave @L i am
          @L-i-am said in How to delete a post:
          Three little vertical dots on the lower right corner of the post click on the , hit delete on the drop dorm from 3 down
          That is what I did but the posts are still there. πŸ˜–
          Look at the last 3 posts in the RayScaper Learning-Practice thread.
          L Rich O BrienR 2 Replies Last reply
          • L
            L i am @ntxdave
            @ntxdave Not an expert on this mate but have you tried signing out, close Sketchucation down and opening it again and signing in and then try to delete it again
              Rich O Brien Moderator @ntxdave
              @ntxdave Only you see the ghosted content you deleted. It's not visible publicly
              • ntxdaveN
                ntxdave @Rich O Brien
                @Rich-O-Brien Thanks Rich. I wondered about that. πŸ‘
