    Stretched material when extruded?
    2 Posts 2 Posters 285 Views 2 Watching
    • L
      Hi, sounds like a newby question, but here goes, I often use exploded images to do , say the facade of a building. I did exactly that on this occasion. When I did so and imported into twinmotion and added a TM material the material is stretched in the fashion of intrusion as per the image. How do I remedy this?Screenshot 2024-06-09 190919.png
        That's UV projection.
        Select the face in SketchUp, right click and check if its set to Projected.
