    "Transforming Colors into Materials: A Plugin Inspired by Adobe Kuler"
    7 Posts 3 Posters 1.1k Views 3 Watching
    • bagateloB
      bagatelo
      I would like a plugin that extracts the colors from a figure and transforms them into materials, but without images, just the pure colors. See the figures on the Adobe Kuler website.![alt text]AdobeColor-Northern Coast of Spain 2024.jpeg AdobeColor-Coral Teal Gray.jpeg AdobeColor-Aileen.jpeg AdobeColor-Önundarfjörður Pier - Iceland.jpeg AdobeColor-Colors of rainbow. Pattern of multicolored butterflies morpho, texture background..jpeg
        Until such time as someone figures out and writes an extension to do that you can do it natively. I imported your first two images as images into SketchUp. Then select a random color from the native Colors collection and added it to the model. Under the Edit tab I selected the eyedropper to sample a color, named it, and then clicked on the Create New Material button.
        Rinse and repeat for the rest of the colors.
        bagateloB 2 Replies Last reply
        Reply Quote 2
        • bagateloB
          bagatelo @Dave R
          @Dave-R Thank you very much
          • bagateloB
            bagatelo @Dave R
            @Dave-R I felt like a complete idiot, I knew there was this function but I couldn't use it, I haven't used Sketchup lately.
            • bagateloB
              bagatelo
              I tried to create the desired script with chatgpt, but I didn't get the desired result, the colors are simply not obtained from the desired points. As a goal this script should do this, but it cannot. Can anyone fix it?
              This script extracts colors from a selected image in SketchUp. It resizes the image to 100cm x 150cm, moves it to the origin (0, 0, 0), and defines specific points in centimeters where colors will be extracted. It then converts the image to PPM format, reads the colors at the specified points, and creates materials in the SketchUp model based on these colors. Additionally, it adds guide points for debugging purposes. Finally, it provides a menu item under "Plugins" in SketchUp to execute the color extraction process.
              require 'sketchup.rb'
              require 'tempfile'
              module ColorExtractor
                def self.extract_colors(image_path, points, width, height)
                  colors = []
                  Tempfile.open(['image', '.ppm']) do |tempfile|
                    # Converte a imagem para PPM usando o ImageMagick
                    system("convert \"#{image_path}\" -resize 1600x2400! -depth 8 PPM:#{tempfile.path}")
                    # Verifica se o arquivo foi criado corretamente
                    unless File.exist?(tempfile.path) && !File.zero?(tempfile.path)
                      UI.messagebox("Failed to convert image to PPM format.")
                      return []
                    # Lê o arquivo PPM
                    File.open(tempfile.path, 'rb') do |file|
                      header = file.readline # Tipo PPM (ex. P6)
                      img_width, img_height = file.readline.split.map(&:to_i) # Dimensões da imagem
                      max_value = file.readline # Valor máximo de cor
                      # Converte os pontos em cm para pixels, considerando a origem no canto superior esquerdo
                      pixel_points = points.map do |x, y|
                        pixel_x = (x * img_width / width).to_i
                        pixel_y = (y * img_height / height).to_i
                        [pixel_x, img_height - pixel_y - 1]
                      # Extrai as cores dos pontos específicos
                      pixel_points.each do |x, y|
                        file.seek(3 * (y * img_width + x), IO::SEEK_SET)
                        rgb = file.read(3)
                        if rgb.nil? || rgb.size < 3
                          UI.messagebox("Failed to read color at point (#{x}, #{y}).")
                          next
                        r, g, b = rgb.bytes
                        colors << { :color => [r, g, b], :point => [x, y] }
                  colors
                def self.create_materials_from_colors(model, colors, image_filename)
                  materials = model.materials
                  colors.each_with_index do |color_data, index|
                    color = color_data[:color]
                    point = color_data[:point]
                    material_name = "#{image_filename}_Point#{index + 1}_#{point[0]}_#{point[1]}"
                    material = materials.add(material_name)
                    material.color = Sketchup::Color.new(color[0], color[1], color[2])
                def self.create_guide_points(model, points)
                    point = Geom::Point3d.new(x.cm, (150 - y).cm, 0) # Ajustando para considerar o canto superior esquerdo
                    model.active_entities.add_cpoint(point)
                def self.run
                  model = Sketchup.active_model
                  selection = model.selection
                  if selection.empty? || selection.length != 1 || !selection.first.is_a?(Sketchup::Image)
                    UI.messagebox("Please select a single imported image.")
                    return
                  image_entity = selection.first
                  image_path = image_entity.path
                  image_filename = File.basename(image_path, ".*")
                  unless File.exist?(image_path)
                    UI.messagebox("The image file does not exist.")
                    return
                  # Redimensiona a imagem para 100cm x 150cm
                  image_entity.width = 100.cm
                  image_entity.height = 150.cm
                  # Move a imagem para a origem (0, 0, 0)
                  tr = Geom::Transformation.new(ORIGIN)
                  image_entity.transform!(tr)
                  # Pontos em cm onde as cores serão extraídas, considerando a origem no canto superior esquerdo
                  points = [
                    [18, 25],
                    [50, 25],
                    [82, 25],
                    [18, 85],
                    [50, 85]
                  # Adiciona pontos guia para depuração
                  colors = extract_colors(image_path, points, 100, 150)
                  if colors.empty?
                    UI.messagebox("No colors extracted from the image.")
                    return
                  UI.messagebox("Materials created from image colors.")
                unless file_loaded?(__FILE__)
                  UI.menu("Plugins").add_item("Extract Colors from Image") { self.run }
                  file_loaded(__FILE__)
                Rich O Brien Moderator @bagatelo
                @bagatelo I'd do the reverse. Feed ChatGPT the image and ask it to generate the rgb values. It will even generate the necessary .txt file.
                Then use ThruPaint or MatSim to import the Color Fan
                bagateloB 1 Reply Last reply
                • bagateloB
                  bagatelo @Rich O Brien
                  I got what I wanted, but I had to do a python script to get what I wanted. Chatgpt helped me a lot. See the zip file attached in the link. There are the scripts, the images downloaded from the Adobe Color website, and an skp file with the results of everything I wanted.
                  https://www.dropbox.com/scl/fi/r02n9htl725rajx9ywtco/adobe.zip?rlkey=34xiw9xw8dykpest4g7lcq3va&dl=0
