    How do I use follow me tool when the lines split?
    Scheduled Pinned Locked Moved Solved SketchUp Discussions
    3 Posts 3 Posters 373 Views 3 Watching
    • S
      Sovmot
      Normally i use the follow me tool but in this case (see image), the line split. Follow me doesn't work in this case (or i dont know how). Do you guys have a plugin that will help me with this?
        You can't. FollowMe works on a continuous edge with no branching.
        PipeAlongPath would help you do it fast than native FollowMe but you still need to work on continuous non-branching selections.
        If you do it so you can mirror and then union it will save some steps
        • Rich O BrienR Rich O Brien marked this topic as a question on
        • massimoM
          massimo Moderator
          It depends on what you want in the corners. If you don't need something too polished you can also use this plugin:
          [Plugin] Lines to tubes
          Hi all, Here is an update of my former script "line2cyl.rb". Intended to create renderable wire frame models. Some bug fixes and enhancements: Make group of...
          sketchucation (community.sketchucation.com)
          It will work in one go: select all the lines and launch the plugin.
