    Transform selection to a circular shape
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    7 Posts 3 Posters 702 Views 3 Watching
    • P
      pjalbert
      ![alt text](circular shape.png image url)
      Hi all,
      Is there a plugin that can transform a couple of selected faces into a circular shape ? Similar like is possible in Blender 3d Loop Tools.
      TIGT 1 Reply Last reply
      • TIGT
        TIG Moderator @pjalbert
        @pjalbert
        To do 'my' method with a 3d surface you could make a group of the octagon and PushPull it into a 'cylinder'.
        Then Move it over the mesh node and move though the mesh, so that you can then select it and the mesh and use context-menu intersect with selection.
        Move/delete the cylinder and the octagonal outline will be drawn over the mesh.
        Then move its nodes to suit...
        Fredo's Tools on Surface would also let you draw on octagon directly onto the mesh surface...
        P 1 Reply Last reply
        • TIGT
          @pjalbert
          No need for a plugin.
          1.
          Draw an octagon [8 sided polygon]
          Center it on an intersection.
          2.
          Use Move on some intersections to snap to the
          octagon's nodes...
          • Rich O BrienR Rich O Brien marked this topic as a question on
          • P
            pjalbert @TIG
            @TIG
            Thanks πŸ˜‰.
            This is the way I do it now. But I was looking for a more automatic way via a plugin to do it because sometimes the mesh is not flat but a bit curved.bob 2.png
            TIGT BoxB 2 Replies Last reply
            • TIGT
              @pjalbert
              • BoxB
                Box @pjalbert
                @pjalbert
                Looks like you are wanting SUbD.
                • P
                  pjalbert @Box
                  @Box
                  Indeed πŸ™‚
                  What are the tools you have used to make the geometry (circle)
                  • P
                    pjalbert @TIG
                    @TIG
                    Thanks for your reply.
                    I will try out .
