    "Sketchup go" question
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    4 Posts 2 Posters 447 Views 2 Watching
    • L
      Hi has anybody here had any experience with "sketchup go"? I do not use layout so I am thinking about changing to go due to the price
        @L-i-am Go is Sketchup for Web through your browser with no extension support.
        If you want SketchUp desktop app you need the Pro plan. They don't offer a plan for just SketchUp without its companion apps.
        L 1 Reply Last reply
        • L
          L i am @Rich O Brien
          @Rich-O-Brien said in "Sketchup go" question:
          Thanks, how do I mark a question solved/ answered?
            @L-i-am said in "Sketchup go" question:
            When you are creating a topic there's an option to 'Ask a question'. If you use that then you can pick the correct answer.
            Not sure if you have the ability the retro-actively edit your post to convert from a topic to a question?
            If you do then try it and see you can mark my reply as correct.
            • L L i am marked this topic as a question on
            • L L i am has marked this topic as solved on
