    Rayscaper New Releases
    rayscaperrender
    814 Posts 14 Posters 384.4k Views 15 Watching
    • pixelcruncherP
      @Krass
      The Animal Fur preset sets Coloring to Natural: the hairs get a natural brown color, like a real animal's coat, and the texture only tints that brown. So your gray and white cat turns brown. The surface under the fur uses a darker version of the same color, which is why it looks brown even without fur.
      To keep the texture, choose Animal Fur, then open Advanced in the Fur settings and change Coloring (under Color) to Dyed. The hairs then take the colors of your texture.
      As Mike says, for a short-haired cat, also make the fur much shorter and less dense.
      I think a textured animal should just work with Animal Fur, so I'll change that. If it does not work, can you send me the cat model? Then I can test with it.
      Cheers,
      Thomas
      KrassK 1 Reply Last reply
      • L
        lightscape Newcomers @pixelcruncher
        @pixelcruncher
        Thank you for your work. My tutorial will be released gradually, and I will send you the video link.
        • L
          lightscape Newcomers @Krass
          @Krass
          I also found a model of eating cats, but I couldn't handle its face well. Fur always affects its mouth and eyes, so I asked it to turn around and look back at the grass.. Fur needs to be very short to show the state of a cat回望草地的猫.png
          @pixelcruncher
          I have also submitted this test to the Showcase🐱
          Reply Quote 2
          • L
            @Krass
            Yes, I have tried restarting Rayscaper and still encounter this issue
            • KrassK
              Krass @pixelcruncher
              @pixelcruncher
              Ah, yes,
              there was a trick to it! You thought of everything!
              This cat still has a bit of "hair loss," but he’s making progress.
              Rayscaper
              Krass
              • pixelcruncherP
                pixelcruncher Extension Creator @lightscape
                @lightscape Yeah, this is a genuine bug. I'm fixing it for the next release (likely somewhere next week).
                • KrassK
                  Krass @lightscape
                  @lightscape
                  I really like your image,
                  At first, I thought you’d sent a photo... I said to myself: that’s cheating in this fur-themed contest!
                  Yeah, your cat still looks a bit like a carpet, but it’s getting closer. may be a young cat, with strong fur.
                  I think it’s the same model from the 3D Warehouse that we used.
                  Krass
                  • KrassK
                    Krass
                    Thomas,
                    I’ve actually added two light panels, matching the size of the two corner windows—it’s a great improvement, it changes everything. The only downside is that I lose that realistic, high-contrast, daylight-style atmosphere. For this version, I went with 1440p resolution and 512 samples per pixel (spp); I’ll send the raw file over via email.
                    Krass
                    • KrassK
                      Krass
                      higher density fur cat
                      Rayscaper
                      Krass
                      L 1 Reply Last reply 👍
                      • L
                        @Krass
                        Very nice!
                        • 37
                        • 38
                        • 39
                        • 40
                        • 41
                        • 41 / 41
