    Rayscaper New Releases
    rayscaperrender
    781 Posts 14 Posters 357.9k Views 15 Watching
    • pixelcruncherP
      Hey, Rayscaper users!
      Rayscaper 1.0.0 is available. You can get it via:
      • The SketchUcation store.
      • Direct download: Rayscaper_Win_1.0.0.rbz.
      I recommend upgrading to the latest version.
      Rayscaper 1.0: Out of Beta
      After many releases of Beta, Rayscaper is now 1.0. A big thank you to everyone who tried the betas, reported bugs and shared renders here: it shaped Rayscaper more than you think.
      Fur Material
      Paint a face with the new Fur material and Rayscaper grows real strands on it in the render: shag and short pile rugs, sheepskin, faux fur throws, plush cushions, even the coat of an animal. Start from a preset and tune the length, density and curl. An image texture colors every strand where it grows, so a patterned rug keeps its pattern. See Fur Material.
      Rayscaper rug in Fur
      Close-up of the rug
      SketchUcation runner in Fur
      Sheepskin
      Wind for Grass
      The Grass material gets Wind and Wind Direction, which lay the grass over one way, and stronger mowing stripes. The online material library now has thirty Grass materials: lawns, sports turf, meadows, wild grass and artificial turf. See Grass Material.
      A New Look
      The render window has a calmer, darker look with clearer selections.
      What Changed?
      • Add the Fur material: paint a face with it and Rayscaper grows real strands on it in the render, for shag and short pile rugs, sheepskin, faux fur throws, plush cushions, long hair and the coat of an animal. Fur hangs down under gravity on walls and over rounded shapes, and an image texture colors every strand where it grows.
      • Add Wind and Wind Direction to the Grass material, and lean whole clumps for stronger mowing stripes.
      • Add thirty Grass materials to the online material library.
      • Give the render window a new look: calm dark surfaces, clearer selections and a new UI font.
      • Take Rayscaper out of Beta.
      • Fix dark soft edges and fades in PNG and TGA textures with transparency, and transparent images that were saved too bright.
      • Fix a crash of CPU renders when the model changed while the render ran.
      • Wrap buttons that ran past the edge of a narrow scene editor panel, and translate the Browse button.
      Full release notes: rayscaper.com/manual/release-notes
      Help Me Build the Community 👍
      If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
      Follow me on X.
      Happy Rendering!
      Thomas
      • A
        Alattab
        pixelcruncherP A 2 Replies Last reply
        • pixelcruncherP
          pixelcruncher Extension Creator @Alattab
          @Alattab Okay, thanks for the image. That makes it very clear 🙂
          A 1 Reply Last reply
          • KrassK
            Krass
            that's why I think this type of effect should be done in post production.
            Did you use 3D fontain water? There are several on the 3d warehouse
            Krass
            A pixelcruncherP 2 Replies Last reply
            • A
              Alattab
              I believe it is essential to include a material type or tab that mimics "billboard" elements—specifically for materials that the user does not wish to fully render, but rather wants to configure for properties like alpha, masking, casting shadows, and receiving shadows. Adding this would significantly enhance the value of RayScaper. Currently, the absence of this feature—which is available in software like SketchUp—sometimes forces me to use other applications instead. I strongly recommend this addition; you can see similar implementations in programs such as Thea Render, SimLab Composer, and others.
              • A
                Alattab @Krass
                @Krass Suppose you have dozens of nozzles; imagine how many water droplets will have their light-related properties manipulated.
                • A
                  Alattab @pixelcruncher
                  @pixelcruncher I believe it's essential to include a material or tab that simulates billboard elements and materials for which the user doesn't want to render; they only want to define alpha, mask, cast shadow, and receive shadow. This would enhance the value of Rayscaper. Sometimes, this feature is unavailable here, even though it's available in SketchUp, so I recommend it. You can see this in several programs like TheaRender, SimLab Composer, etc.
                  • pixelcruncherP
                    @Krass here's the fur example scene to try out: https://scenes.rayscaper.com/rayscaper-fur-example.skp
                    • KrassK
                      Krass
                      Thanks a lot!!!! Tonight I missed your post about the V1.0...
                      So exited to test the fur, tomorrow morning! Champagne!
                      Krass
                      Reply Quote 2
                      • A
                        Alattab @Alattab
                        A "fake emission" texture type can be used to prevent shadows from being cast onto a surface.
                        • A
                          Alattab
                          It would be great if you could add presets for the sun for different times of the day and night.
                          • A
                            Alattab
                            what about decal
                            Decal Renderer Feature | Universal RP | 14.0.12
                            (docs.unity3d.com)
                            • A
                              Alattab
                              • KrassK
                                Krass
                                Rayscaper
                                This is truly excellent—thanks for adding this option so quickly!
                                I’ve just posted a new message in the Rayscaper section of the French forum Biblio 3D to mark the release of version 1.0.0, including a summary of all the available features:
                                [ RAYSCAPER ] Rayscaper 1.0.0
                                Rayscaper pour Sketchup version finale vient de sortir, fini les beta. Disponible aussi pour Mac https://sketchucation.com/plugin/2677-rayscaper Le programme es
                                www.biblio3d.com (www.biblio3d.com)
                                I’ve created this initial render; please forgive me for not being able to resist the kitschiness of this sofa...
                                Krass
                                • KrassK
                                  Krass
                                  However, this first render is slightly blurry; I hadn’t touched any of the settings... Could it be related to the heavy demands that the "Fur" places on my graphics card? I’m not sure—perhaps I accidentally moved a slider somewhere...
                                  Krass
                                  • pixelcruncherP
                                    @krass Very cool render, I forgive you for the kitsch 🙂
                                    I changed the denoising; it kicks in a bit earlier, so maybe that's why the render looks blurry? Do you prefer a noisy first render over a blurry one?
                                    Cheers,
                                    Thomas
                                    • KrassK
                                      Krass
                                      tu avais déjà fait cette modification du débruiteur auparavant je crois.
                                      je ne sais pas, mais je me rappelle aussi qu'il y a des paramètres de filtres de pixels..
                                      mais je vais continuer les tests voir si c'est pas plutĂ´t du ressort de l'opticien...
                                      Krass
                                      • pixelcruncherP
                                        @krass
                                        The pixel filter and the denoiser are two different things. The pixel filter sets how much each sample spreads over the pixels around it, so it decides how sharp the image is, whether or not it's denoised. The denoiser only cleans up the noise, and it's the part I changed, not the pixel filter.
                                        Cheers,
                                        Thomas
                                        • KrassK
                                          Krass
                                          here is a render 1024 Spp in 1080 p.
                                          If other users could take a look—I find it a bit sluggish.
                                          Krass
                                          • KrassK
                                            Krass
                                            If other users could take a look—I find it a bit sluggish. :
                                            https://jskup.fr/wp-content/uploads/2026/11/testnet.png
                                            Krass
