    ANIMATOR - ASSEMBLING A MODEL
    4 Posts 3 Posters 253 Views 3 Watching
      raphaelhalfon Newcomers
      Hi everybody!
      I'm very new to sketchup and thus also to Sketchucation.
      In Animator, I'd like to assemble a model with translations.
      Outside Animator, I want to see the assembled model.
      Inside Animator, the model starts disassembled and finishes assembled.
      Is there a way to do this without disassembling the model outside Animator ?
      • Rich O BrienR Online
        If you reverse your animation then starting assembled and finishing exploded your good to go.
        Animator has an Explode from Center feature but its no longer working...
        https://i.imgur.com/YRPTQYZ.png
        ...that's not helping but its obviously planned at some point.
        This does sound like a brute force scenario whereby you just dive in and get your hands dirty and when you hit a wall come back.
        In theory if your pieces are components and your local axes is orientated in such a way then you could do a explode type animation with the minimum amount of translations
        In the export options you can export your animation end to start
        https://i.imgur.com/6QdzX6x.png
        anim-explode.skp
        • ntxdaveN Offline
          ntxdave
          Not sure this is what you are looking for but here is a video exploding a model with Animator.
          Animator Explode.mov
          Press F1...thank me later
          • ntxdaveN Offline
            ntxdave
            Here are some updated files. The SketchUp file is version 2020.
            Animation Video
            SketchUp Model
