    Uninstall Plugin
    7 Posts 5 Posters 364 Views 5 Watching
    • ntxdaveN Offline
      ntxdave
      What is the best/recommended method to uninstall a plugin?
      Press F1...thank me later
      • ntxdaveN Offline
        ntxdave
        Interesting that I have not received any responses. Is it safes to just delete a plugin or am I missing something obvious?
        • tuna1957T Offline
          tuna1957
          ntxdave, unless things have changed ( I’m on SU18 ) Open the Extension Manager window in SU. Click on Manage and you’ll have the option to uninstall whatever plugin you want.
            It depends on the extension.
            • ntxdaveN Offline
              ntxdave
              DUH - I should have remembered this. Issue Solved 👍
              DaveR - it was the Rayscaper plugin. It currently has a problem with SU 2020. They are now aware of the problem. Thanks for your reply though. 👍
                Press F1 with Sketchup open and you get info on relatively common queries.
                • sketch3d.deS Offline
                  sketch3d.de
                  Windows: for an extended extension (and not a simple plugin) with an own installer (EXEcutable) for a complete uninstallation (incl. e.g. program settings) you may want use the according uninstaller typically provided by the software control panel tool of the Windows control panel ("Win+R > control...").
