    OPENAI Explorer Extension
    4 Posts 4 Posters 490 Views 4 Watching
    • G
      greenelmco
      I have this extension installed and have watched the videos. I have a Key and have matched the settings in the tutorial videos, however whenever I type a simple command (Draw a 2" x 2" square), nothing happens. My initial thought was to uninstall and reinstall, but I cant even find how to uninstall it. It is not showing up in the Extension manager. I am using SU2023 Pro
        For a fresh install you need to go to
        C;\Users\SomeName\AppData\Roaming\SketchUp\SketchUp 2022\SketchUp\Plugins
        In Windows the appdata folder is hidden so an easy way to open is to just use Extensions > Sketchucation > Open Plugins Folder...
        Delete the as_openaiexplorer folder and the as_openaiexplorer.rb file
        Then restart SketchUp and install it again.
          Please update your forum profile. It's way out of date and if it was correct you wouldn't have to include that in your posts.
          • alexschreyerA
            alexschreyer Extension Creator
            I completely missed this thread. Glad you gave the extension a try. Here's also an update:
            I recently published version 3.0 which can now be used also with other services like Google (tested), Anthropic, DeepSeek (untested). As a result, I also renamed the extension. Give it a try...
            https://alexschreyer.net/projects/openai-explorer-experimental/
            Author of "Architectural Design with SketchUp":
            http://sketchupfordesign.com/
