    Fredo6 not working
    4 Posts 4 Posters 179 Views 4 Watching
      robertperssondesign Newcomers
      I have installed LibFredo6 and then roundcorner. I have been playing around with it for a couple of days but when i tried to used it today it wasn't there anymore. When I start SU it tells me to install LibFredo6. It is already installed but i uninstalled and then installed again. Still no luck. It shows up but it's like it isn't running. Any help much appreciated!
        What version of SketchUp are you really using? You put 2023 Free/Make in your profile. The only free version of SketchUp offered in 2023 is the web based version which doesn't have any facility to use extensions.
        Assuming you have SketchUp Pr instead, first make sure you installed it correctly. That requires right clicking on the installer and choosing Run as administrator. Do that now ad choose the Repair option.
        After that, make sure you have the current version of the Sketchucation Extension Store installed and use it to install the most recent version of LibFredo6 as well as Round Corner. After that close and reopn SketchUp.
        Please correct your forum profile, too.
        • BoxB Offline
          I suspect nobody really cares, but this is the sort of thing that has 'reduced' my interest in replying to posts here.
          Dave answered a question as fully as possible with the info given and correctly asked the OP to give more info and correct their profile as that information is needed for us to help them.
          And what happens.
          Two sad bastards click the thumbs down button.
          I can assure you the beards really do make you look like counts.
            Well, I am to blame for the anonymous voting system...
            But the next forum has it so anonymity for opinions is not possible
            https://i.imgur.com/FURfEsI.png
