    Puffy sail
    7 Posts 4 Posters 322 Views 4 Watching
      drybrae
      I am trying to draw a square sail puffed with air. Any suggestions? I am trying to add a .jpg file (picture) of my failed attempts at this to show you what I have done. I find it impossible to attach a .jpg. Besides help on drawing the sail, I would like instruction on how to attach .jpg files to this forum.
        The Clothworks extension sounds like just what you need.
        Click on Upload Attachment at the bottom of the post window, then Choose File, select it and upload it.
        • HornOxxH Offline
          HornOxx
          ... or maybe the good old "Soap Skin Bubble" could be the right tool?
          https://extensions.sketchup.com/extension/c8d49537-51db-40a7-ac0e-474a244eb525/soap-skin-bubble
          never trust a skinny cook
            drybrae
            I am trying to draw this Viking boat for 3D printing so the sail needs thickness. The sail in the picture was done in soapbubble, I have not tried Clothworks yet. Can either soapbubble or Clothworks add thickness to the sail with a smooth appearance? If not, is there any way to do it?
              I would use the Draw > Sandbox > From Scratch menu to create the sail size and Tools > Sandbox > Smoove to form the effect...
              https://i.imgur.com/79pXowE.png
              Thor on a surfboard!
              • HornOxxH Offline
                HornOxx
                ...how about to start with something like "thanks for the suggestions here but I forgot to mention that I want to 3d-print it..."?
                I have no experience with 3d printing so far but I think Fredo6´s Joint Push Pull tool works well for adding thickness
                  It would have been helpful if you'd indicated you want to model the sail for 3D printing.
                  In your image it is evident you didn't do the thickening of the surface correctly.
                  Clothworks and then Joint Push/Pull to add the thickness.
                  The result in the slicer.
