    Need Urgend Help!
    7 Posts 5 Posters 293 Views 5 Watching
    • H Offline
      Himbeertoni
      Dear Community,
      I need your help!
      the task i can not do:
      Simplefided:
      Draw a loooon recktangle box, lets say about 1 m long 30cm high.
      Draw a second rectangle box inside the first one wit a spce of 4 cm on each side.
      Draw now small lines from the corner of the outsidebox to the corner of the inside box (4x)
      So far so easy.
      but now the inside box should be with "push/pull" moved 5 cm out...... but the connected 4 surfaces
      should morph too.
      The result it should ve a four-sided Trapetz body.
      May there is a free plug-in? additional restrictions i have is a old Laptop so only SU2016 runs here. ;o)
      Thank you for all constructive support!
      • BoxB Offline
        You wouldn't use pushpull, you would use the move tool.
        Select the inner rectangle and use the move tool to move it 5cm up.
        • HornOxxH Offline
          HornOxx
          ...or if only the geometric resulting shape is important to you, the "Follow Me" methods might also be helpful.
          never trust a skinny cook
            I suppose you can also draw a box then resize the top! πŸ˜‰
            • panixiaP Offline
              panixia
              You don't even need to draw the 4 segments to join the corners.
              Autofold will create them automatically.
              Just do the following:
              _Hit "R" on your keyboard
              _Left click
              _Type "100;30" and hit "Enter" key
              _Hit "F" key and hover over the rectangle you just created, click drag the hilighted border
              _Type "4" and hit "Enter"
              _Hit "M" key
              _Hover on the inner rectangle click and drag it somewhere
              _Hit the up arrow key and drag up with mouse
              _Type "5" and hit "enter"
              _Job jobbed.
              • H Offline
                Himbeertoni
                Thank you all ! Im going to try-out all of your leads. "Box" : this is defnetly i want!
                Seems soo eays 😲
                • H Offline
                  Himbeertoni
                  @ Box
                  @ all: again a very THANK YOU !
                  i used on the end the solution of "BOX" and feel a bit silly. Sooo easy
                  this topic is solved .
