    [Plugin] FredoSketch - v1.7a - 17 Dec 25
    35 Posts 9 Posters 7.4k Views 9 Watching
    • panixiaP Online
      panixia
      @pedroe said:
      even better, that hot boxes appear at the main points (vertices, midpoints, etc) that allow you to choose whether to move (default command), copy, rotate, scale, move and rotate. It could be something as fun as this, to manipulate only with the mouse.
      please, no.
      • panixiaP Online
        panixia
        @fredo6 said:
        The Texture positioner is the worse method to manipulate objects.
        Ditto. It's a freakin' toy.
        @fredo6 said:
        One way to combine several transformations is to use a Gizmo
        Please yes! β˜€
        I suggest to use the local axis origin point as default point to place it when a object is selected and the center of masses when multiple objects are selected (without having to reposition it every single time, that could be a context menu option or something). A toggle between origin and center could be very "industry standard" too.
        • P Offline
          PedroE
          In principle, I do not mean that they are object handlers, but that those icons that appear allow once the input command is executed (by default to move) then they allow us to choose if we copy, scale, rotate, mirror, etc. In other words, an initial command derives in all the other movements that we can make to an object, without having to choose a command each time. The object manipulator points you already do with the most efficient way that you consider.
            rv1974
            Simple keyboard shortcuts are way faster than any icons upon objects you are dreaming of.
            • P Offline
              PedroE
              It is about not losing the focus of attention on the object to be manipulated, not everyone likes keyboard shortcuts. In this way you optimize mouse movements, in addition to the fact that the future comes with touch screens, similar to what sketchup for ipad does.
              • fredo6F Offline
                fredo6
                Then, you can have a simple toolbar with at the top of your screen. Normally, FredoSketch selects the objects being moved or rotated when exiting. So you can probably chain with another tool.
                • E Offline
                  Einstein
                  Hi, Fredo,
                  You probably have it on your to-do list already, but remembering and revoking lastly used soft-selection radius would be a great improvement. Now it jumps back to zero when the tool is activated again (and when it was used previously with larger radius). For comparison, Blender always remembers the last value for proportional editing.
                  Great tool, though. I've been asking ThomThom for years to expand his Vertex Tools with more falloff options, and here we are with FredoSketch!
                  • fredo6F Offline
                    fredo6
                    @einstein said:
                    Hi, Fredo,
                    This is possible. I probably save it at model level
                    Vertex Tools does a lot more... and I think it has fall-off methods too.
                    • P Offline
                      PedroE
                      Example of manipulation by gizmos:
                      • P Offline
                        PedroE
                        This was what i meant:
                        although it is still room for improvement. I encourage you to do it. All the best.
                        • fredo6F Offline
                          fredo6
                          NEW RELEASE: FredoSketch v1.3a - 30 Dec 23
                          Requirement: LibFredo6 13.7b
                          FredoSketch v1.3a is a maintenance release:
                          • Extension of Validity
                          Home Page of FredoSketch for information and Download.
                          Main post of this FredoSketch thread.
                          • fredo6F Offline
                            fredo6
                            NEW RELEASE: FredoSketch v1.4a - 02 Apr 24
                            Requirements:
                            • LibFredo6 14.3b
                            FredoSketch v1.4a is a maintenance release:
                            • Future compatibility
                            • fredo6F Offline
                              fredo6
                              NEW RELEASE: FredoSketch v1.5a - 31 Dec 24
                              Requirements:
                              • LibFredo6 14.3b
                              FredoSketch v1.5a is a maintenance release:
                              • Extension of validity
                              • fredo6F Offline
                                fredo6
                                NEW RELEASE: FredoSketch v1.6a - 01 Jun 25
                                Requirements:
                                • LibFredo6 14.3b
                                FredoSketch v1.6a is a maintenance release:
                                • fredo6F Offline
                                  fredo6
                                  NEW RELEASE: FredoSketch v1.7a - 17 Dec 25
                                  Requirements:
                                  • LibFredo6 15.6
                                  FredoSketch v1.7a is a maintenance release:
                                  • 2 / 2
