    Grooves running upwards
    6 Posts 4 Posters 310 Views 4 Watching
    • A
      Alohaa
      Hello,
      is it possible to have the grooves in the object in the attached file taper upwards onto the surface 2cm before the top and end edges?
      I have no idea how to do this.
      Sincerely
      ProApe
      Grooves.skp
        Not sure if I fully understand your query. But from what you typed I arrived here...
        https://i.imgur.com/CMsX5k0.png
        • BoxB
          Like Rich I'm not sure what you want as such, this is another guess.
          The taper is 2cm long and it is 2cm from the end.
          This requires you to understand how to use the cardinal points, something well worth learning about.
          Note.The centre line I put in before flattening the curve is like a safety valve, without it the geometry can go a bit nuts, but can be removed when done. And drawing the edge over the end of the taper is just a lazy way to unsoften the edge at that point.
          https://i.imgur.com/YRgbWE4.gif
          • A
            Alohaa
            very nice and complicated! thank you
              Another option for doing this sort of thing. Gives you a different look and maybe not what you want.
              • A
                Alohaa
                No, that's not really what I want.
                I was able to reproduce the first solution (but it is not easy to see if it worked or not), but the second one didn't work.
